bumping noise
Old Aug 26, 2025 | 04:22 PM
Ernesto's Avatar
Default bumping noise
anyone got any ideas on what may be making a dull bumping noise from n/s/r at low speed whe turning left
Old Aug 26, 2025 | 05:27 PM
BruceTheQuail's Avatar
I had that a few years ago after a service and it ended up that the spline nuts on the wheel hadnt been tightened and the wheel was loose, then the bearing went not long after. I cant remember if the bump was the loose wheel or the bearing, it might have been the latter.
Old Sep 1, 2025 | 09:14 AM
schuss's Avatar
When I had that, the nuts on the front shock towers that hold the shocks down had worked loose. It seems like once a year I have to re-tighten them as they work loose.
Old Sep 5, 2025 | 07:54 AM
TangledThorns's Avatar
Could be a ball joint going bad. I recommend getting it looked at ASAP before it goes completely and you're stuck somewhere or worse at speed. Happened to me in my Nissan and it sucked trying to get it on the tow truck bed.
Ernesto
Aug 28, 2025 12:05 PM
Martinpas
Aug 24, 2024 12:48 AM
Elizabeth Blake
Sep 17, 2019 08:12 PM
shotime92
Jul 30, 2013 10:10 PM
