Camshaft position error
Old Feb 17, 2022 | 04:18 PM
manuninja's Avatar
Default Camshaft position error
Hi guys,
after having the amber engine warning light for about a week, i got myself a diagnostic tool: icarsoft lr 2.0.
After running a scan I found these errors:
P000A - Jaguar A Camshaft Position (CMP) Slow Response (Bank 1)
P000B - Jaguar B Camshaft Position (CMP) Slow Response (Bank 1)
P0011 - Intake Valve Timing Control Performance Bank 1 - “A” Camshaft Position – Timing Over - Advanced or System Performance
Reading on the internet the causes could be the
Low oil pressure due to restriction in an oil passage or a bad oil pump
A faulty camshaft position sensor
A faulty camshaft position actuator solenoid
and other things not at all nice to read...
Car is 2.0 My2019 with 26000KM.
Any advice? I'm really worried...
Thanks in advance for any suggestions and tests I can do on my own.
Old Feb 17, 2022 | 04:36 PM
DJS's Avatar
DJS
My XE has the 2.0l Ingenium engine, and I had a camshaft position sensor replaced under warranty - it would occasionally throw a code, which I believe is a known failure. I can't locate the invoice right now to see exactly what they reported. Is yours under warranty?
Old Feb 17, 2022 | 05:26 PM
manuninja's Avatar
Mine is out of warranty from six months.
I don't think it is difficult to change this sensor and I could change it too. I should know where exactly the one in bank 1 is.
Is there a way to test if the cam sensor is in fault?
Possible that the problem concern
camshaft position actuator solenoid?
if you find the invoice and if you remember the error code it would be a good thing ...
Old Feb 17, 2022 | 06:07 PM
Robtrt8's Avatar
VVT failure is pretty common. Dealerships stock them. Double check the item inside the package if/when you get it. JLR has had a bunch of miss-packaged items. (Correct box with the wrong part).
Old Feb 17, 2022 | 08:23 PM
Robc2562's Avatar
I'd check with the dealer because my dealer reached out to me saying there was an open recall for this. When I asked what it was for they had said it was for a camshaft solenoid.
It might be worth taking a look if that's the case
Old Feb 18, 2022 | 04:49 PM
manuninja's Avatar
How understand if is miss-packaged item?
have you pdf of this recall?
Old Feb 18, 2022 | 04:55 PM
Robc2562's Avatar
I don't have a PDF, but this is a clip from the email when I asked what the recall was for
Old Feb 19, 2022 | 01:58 AM
manuninja's Avatar
I found this recall but is for Can/Usa car even if my VIN is covered by the campaign (my is an italian car)
File Type: pdf
Old Feb 19, 2022 | 08:39 AM
Carbuff2's Avatar
Ask a local dealer if it is covered. (sorry for the pat answer) You did good homework!
From the PDF you posted though, it must be really easy to replace. (only 0.2 hour, or less than 15 minutes?)
Old Feb 22, 2022 | 03:03 AM
manuninja's Avatar
I took a look under the hood and I think the two VVT sensors are these:
but what is bank 1?
and i think that the camshaft sensor is one of this?
thanks
Old Mar 23, 2022 | 11:14 AM
manuninja's Avatar
if anyone had the same problem, i solved it by changing both vct sensors
Old Mar 23, 2022 | 11:30 AM
Nodnarb's Avatar
Thank you for posting your resolution!
Old Feb 10, 2024 | 10:25 AM
weeble's Avatar
Default I've got code P0011.
Is it these I need to replace?
Old Feb 10, 2024 | 10:33 AM
manuninja's Avatar
yes. In mine 4 cylindrer are two sensors.
Old Jun 10, 2024 | 12:10 PM
palermo's Avatar
hello What was the problem.. how did you solve the problems??
Old Jun 10, 2024 | 12:13 PM
palermo's Avatar
hello how did you solve the problems. my car have Same problem
Old Jun 11, 2024 | 10:55 AM
manuninja's Avatar
If you read all thread you will understand
Phil m
Aug 25, 2021 10:36 AM
Brit-Type
US Northeast
May 11, 2021 12:48 PM
semorex
Jun 12, 2020 08:47 AM
MarkyUK
Aug 23, 2019 10:39 PM
andre.iamma
May 21, 2019 12:07 PM
