Charger for Tuning
Old Aug 19, 2024 | 05:45 PM
VXN.XKR's Avatar
Default Charger for Tuning
Hi all,
I have a 2017 Base Model V6 F Type. I just purchased the VAP Stage 1 tuning kit for it, and they recommend using a battery charger while completing the process. Would anyone have any suggestions for chargers, preferably ones that are portable and do not need constant AC power but can be charged prior to use?
Old Aug 21, 2024 | 02:02 PM
lizzardo's Avatar
That's not really a charger, but a booster battery. An actual charger would use AC power.
I have a small booster that I got from Amazon a few years ago. It'll start a car, but I'm not sure how long it would stay in the "jump" mode if being used to give extra capacity with the engine not running.
I have retrieved the file from my car and also flashed the new one without a charger connected on a couple of occasions, but there is risk that if the voltage drops too low the ECU could end up bricked.
Old Aug 22, 2024 | 09:53 PM
dennis black's Avatar
Drive the car for 15mins on the highway then flash your Ecu you will be fine
Old Aug 23, 2024 | 09:18 AM
scm's Avatar
scm
I've read that it takes 20 minutes of driving to put back what you take out of it on startup, so I hope the battery was fully charged before you do that. But I guess it depends on how risk-averse you are.
Old Aug 23, 2024 | 09:23 AM
DJS's Avatar
DJS
It also assumes you have a healthy battery. I hooked a 15-amp battery charger to my battery when I flashed my tune.
Old Aug 28, 2024 | 05:40 AM
VXN.XKR's Avatar
Hi All,
Thank you all for your suggestions! After consideration, I decided to buy a Centech charger from Harbor Freight and a buddy of mine ran an extension cord for us to plug it into while I read the ECU. Had no issues with the process, and am currently waiting on VAP to return the tune file to me.
peterv8
Nov 14, 2024 11:46 AM
Greg1967OTS
E type ( XK-E )
Feb 17, 2024 06:43 AM
nw247
Nov 22, 2021 07:14 AM
lpf4
Aug 27, 2021 09:48 AM
rtcosic
XF (X260)
May 25, 2020 01:43 PM
