Check Engine Light Question
Old Apr 21, 2023 | 07:29 AM
Pie944's Avatar
Default Check Engine Light Question
Hi,
MY19 F Type R Coupe, 32k miles. Got a solid check engine light when driving it, drove fine. Took it right away to the dealer who just emailed me the video of the car and stated that it had 'timing correlation faults' and the oil was a little low (Last changed May 22, end of the month). Recommending oil change, clear faults, and will drive around.
Thoughts? Is this normally how the 'timing correlation ' faults are dealt with? I don't know the exact codes yet. It's just concerning since the car is almost out of warranty that I have a feeling this issue is going to pop up again in a few months.
Thank you in advance for your time.
Old Apr 21, 2023 | 07:35 AM
CJSJAG's Avatar
Do not know the answer to your question, though I am sure somebody will suggest it is battery-related!!!
If it were me, I would get it back (assuming the dealer says it is OK) and drive the heck out of it before the warranty expires.
It is also a little odd that the oil level was low.
Presumably the dealer did an oil change last May as part of the annual service - did you check the level since then?
After the initial 2k miles when new, my 2021 V6 burns no oil between 8K mile annual oil changes.
Old Apr 21, 2023 | 07:43 AM
OzXFR's Avatar
In almost all cases a solid CEL means an emissions issue - O2 sensor, cat, EVAP, EGR etc - so usually nothing to really worry about.
Old Apr 21, 2023 | 09:13 AM
Pie944's Avatar
My other concern is the oil consumption. I probably put 6-7k miles per year. I don't know what 'low oil ' is and will find out. Mainly drive to and from work, 70 miles round trip, all highway, mainly 5th @ 80 mph, RPM 3-4k. I've gone back through the oil consumption threads in the forum and it seems the majority of individuals on here who posted have minimal consumption between changes.
Paul
Old Apr 21, 2023 | 09:56 AM
scm's Avatar
scm
Assuming you park on level ground (and it must be really level!) it's easy to check the oil level each time you get in the car. That should give you a good indication of how fast the oil is disappearing.
Old Apr 21, 2023 | 10:24 AM
clubairth1's Avatar
Community Influencer
Do you actually check the oil level? I was not sure from your post?
It seems you waited until the dealer told you it was low?
As you have read it is CRITICAL to keep a sharp eye on the oil level AND the coolant level at all times.
This is really the key to owning a Jaguar.
Old Apr 21, 2023 | 10:53 AM
Pie944's Avatar
I do check it, last check it was 'OK'. The actual marker level can vary but it has always been 'OK'. He stated 'a little low' in the video, so again not sure what that means. I don't mind checking it and adding to it if this is within the normal spectrum. However, I'm worried that the burning is significantly abnormal and concerned about what the underlying issue causing the excess burning of oil is.
Old Apr 21, 2023 | 06:33 PM
George05's Avatar
started off in an xk 4.2 non supercharged, then a few xj diesels and an xkr then a f type v6s and a xj v6 supercharged , they don't Burn oil , in all my years owning them they are rock solid , Audi and BMW on the other hand burn through a litre per month
Old Apr 22, 2023 | 05:52 AM
scm's Avatar
scm
Originally Posted by George05
... Audi and BMW on the other hand burn through a litre per month
And VW, in my limited experience. And that was to spec, apparently!
Sabastien
Dec 15, 2021 02:31 PM
mghirsch
Feb 19, 2020 08:39 AM
JagWire_5280
XF (X260)
Jul 20, 2019 11:07 PM
Charles Blume
Mar 14, 2018 04:52 PM
seraphi
Jul 13, 2017 08:45 AM
