Clock Sets Back To 24hr
Old Feb 23, 2016 | 07:14 PM
postmachina's Avatar
Default Clock Sets Back To 24hr
Running into this issue about every 2 weeks. Even though I set the system to 12hr clock it will revert back to 24hr at least twice a month.
Anyone else dealing with this?
Old Feb 23, 2016 | 07:52 PM
Dremorg's Avatar
Yeah. It's happened to me a couple times.
Old Feb 23, 2016 | 08:13 PM
TXJagR's Avatar
Mine has reset the date from MM/DD/YY to DD/MM/YY, I assumed the date was incorrect and changed it then realized the date WAS correct, just in the wrong format...
Old Feb 23, 2016 | 09:32 PM
IronMike's Avatar
Happened to me with some routine as well. Been a few other settings that seem to revert back to default values for some reason. Have no idea what causes this, but its mildly annoying
Old Feb 23, 2016 | 10:37 PM
Nati's Avatar
as long as the steering wheel stays on the same side of the car...
Old Feb 24, 2016 | 07:43 AM
Jaronstoys's Avatar
Had the same thing happen also
Old Feb 24, 2016 | 07:51 AM
Foosh's Avatar
Weird, never seen this in 2 years.
Old Feb 24, 2016 | 08:06 AM
Unhingd's Avatar
Wouldn't know: I always leave it set to 24 hrs, and never need to know what day it is when I'm driving.
I would, however, notice if the default side for the steering wheel changed. (It has not)
Old Feb 24, 2016 | 08:10 AM
PolkNole's Avatar
Yep - glad I'm not the only one this was happening to. I figured I was causing it somehow.
Old Feb 24, 2016 | 08:48 PM
Mbourne's Avatar
have never had this happen. though i would like the wheel to change sides just for sport.
Old Jul 2, 2016 | 04:06 PM
amr42's Avatar
How is date format changed? Mine is set to DD/MM/YY, but I cannot see any menu item to change it... Other than Language/Locale which is set to English (US)...
Old Jul 2, 2016 | 04:21 PM
Mbourne's Avatar
Well I spoke too soon. Wheel was on the wrong side this morning. Weird.
Just kidding, but when I got it back from service its was in the 24 hr mode. Took me a while to find the setting to change it.
Old Jul 2, 2016 | 04:32 PM
LobsterClaws's Avatar
This happens to me ALL THE TIME! I'm in the process for forcing myself to get used to 24 hr time because otherwise I'm going to go insane.
Old Jul 2, 2016 | 04:34 PM
Uk2usa's Avatar
British Cars always change the date format in America around this time of year to remind everyone that it's the 4th of July. Not July 4th.
I just came up with that one, feel free to use it.
Old Jul 2, 2016 | 04:38 PM
Mbourne's Avatar
Its a nice bit of revenge!
Old Jul 2, 2016 | 05:13 PM
ioneabee's Avatar
everything the way it should be
dd/mm/yr
stearing wheel on the right side
and the world is naturally set back to rights
Old Jul 2, 2016 | 08:26 PM
polarisnavyxj's Avatar
Default Just happened today!
Wow, I just noticed this morning,,,
And just got back from service
Old Jul 2, 2016 | 08:27 PM
Buckingham's Avatar
Check the Incontrol web page set up. You may have it set to military time on the web page and every so often it reverts.
Old Jul 2, 2016 | 08:44 PM
IronMike's Avatar
Sounds like this happens with some routine after cars have been in for service...
Wonder if it's due to a system reset by the dealer, or even a battery disconnect.
Old Jul 2, 2016 | 09:00 PM
Unhingd's Avatar
Yes, disconnecting the battery long enough to reset the battery management module after it goes wonky will indeed reset all the user settings back to the factory default.
