Convertible top not working
Old Aug 17, 2019 | 08:31 AM
Brentster63's Avatar
Default Convertible top not working
Just bought my 2018 F type two weeks ago. Convertible top has been working perfect. Got in the car yesterday and is not working at all. The only thing I did different was try to open it with both doors open. I closed the doors, and nothing. When I close the doors and roll the windows down and push to close, The windows will close and that’s it. I had heard about potential low battery issues. I have no problems starting this car. Any suggestions.
Old Aug 17, 2019 | 10:19 AM
DJS's Avatar
DJS
I’m assuming you’ve tried it with the engine running. In my early car, if ECO shuts off the ignition, then I can’t move the top until I’ve started the engine, not just turn the ignition back on.
Old Aug 17, 2019 | 10:34 AM
RGPV6S's Avatar
What he said. My car is the same way.
Old Aug 17, 2019 | 10:44 AM
sov211's Avatar
Originally Posted by RGPV6S
What he said. My cars is the same way.
And for future reference, the fact that the engine will start does NOT mean that the battery is putting out sufficient voltage to power the multiple modules in these cars. The first signs of a failing or discharged battery will be random:warning lights, various components not operating properly, top issues, touch screen freezing and at some point a message on the screen telling you to "please" (yes) start the engine. The starting system is designed to be the LAST failure point. I am not suggesting that this is the cause of your top issue now -just pointing out something that every owner should know. If this F-Type is to be an occasional-use car then you would be well advised to use a battery maintainer (CTEK brand being the favoured one) when the car is not in use.
Old Aug 17, 2019 | 12:35 PM
scm's Avatar
scm
Originally Posted by sov211
... a message on the screen telling you to "please" (yes) start the engine.
Well, it's a British car - you'd expect it to be polite!
Old Aug 17, 2019 | 03:28 PM
I have tried that. I do have it tuned. I reset it back to factory, nothing. Fuse is good. Took the battery cables off for 30 minutes. I’m at a loss
Old Aug 17, 2019 | 03:45 PM
Unhingd's Avatar
Have you checked the fuse?
Old Aug 17, 2019 | 04:11 PM
Yes
Old Aug 17, 2019 | 04:14 PM
I guess I’ll put a trickle charge on it all night
Old Aug 18, 2019 | 03:45 PM
It is fixed. Charged the battery up all night, next morning works perfect.
Old Aug 18, 2019 | 04:12 PM
sov211's Avatar
Right...it bears saying yet again: for any electrical system on a modern car ( of any make) the battery is the first suspect - it is almost always found to be the culprit (often after elaborate, time-consuming, frustrating and frequently expensive investigations). And very often the notion of insufficient battery voltage as the cause of malfunction is ignored or rejected.
Slee_Stack
Jan 17, 2024 07:20 PM
Calcamper
19
Oct 26, 2019 11:35 AM
SLazz
Feb 6, 2019 02:30 PM
FRGIII2014
Dec 31, 2016 02:22 PM
hypoluxo
Oct 2, 2012 12:48 AM
