Convertible top won’t come down.
Old Mar 2, 2025 | 10:17 AM
Adam Deermann's Avatar
Default Convertible top won’t come down.
Hi,
I’m rebuilding my 3.0 v6 and waiting forever to have the crank shaft grinded. The subframe is out including all the engine and transmission wiring.
Meanwhile I started to replace the rear left quarter panel. Now I need to drop the top to reach some bolts. But the top doesn’t do anything. Beforehand it opened and closed perfectly. Must be all the wiring I disconnected. I checked the fuses, all good.
Does anyone have a electrical schedule of the top? Under which conditions will it open?
thx Adam
2014 V6 base.
Old Mar 2, 2025 | 11:04 AM
DJS's Avatar
DJS
I assume the battery is connected? I’ve found on mine that a shutdown from ECO (Start/Stop) is a harder shutdown than turning off the ignition. My 2nd battery is dead and gone, but previously if ECO shut off the car (for example, by removing the seatbelt before shutting off the engine), then simply turning the ignition on wasn’t enough to operate the roof, I actually had the start the engine.
The folding top section starts at p. 1680. Wiring diagrams are at the end.
https://www.dropbox.com/scl/fi/o6d1x...=5ffcrzxu&dl=0
Old Mar 2, 2025 | 12:39 PM
All fresh battery power. It worked flawless before I took out the engine.
Old Mar 2, 2025 | 01:07 PM
Carbuff2's Avatar
You can't manually crank the top open to access the bolts?
The tools are under the dash, passenger side.
Old Mar 2, 2025 | 01:17 PM
According to the manual it can only be used to close it. But that would be a great solution . Does anyone know if that’s possible?
JaguarXKR
Jan 9, 2025 09:31 AM
jlsthlm
Mar 22, 2020 06:30 PM
pab
XE ( X760 )
May 11, 2016 08:17 PM
Blakeney
Feb 4, 2015 09:02 PM
EZDriver
May 26, 2014 01:49 AM
