Engine clicking noise
Wondering if anyone could help me point out what this engine noise is. Sounds like timing chains. It’s a 2016 F type with 69,000 miles with oil changes every 3k miles. Thanks.
https://youtube.com/shorts/l7eHLlzIQh0?si=ZjpOLDSjPzXyNFU_
Also the indy I took it too wasn’t really sure either.
Have you done the Supercharger coupling replacement yet? If not, that is likely what you are hearing. Many mechanics misdiagnose this as a timing chain issue due to it's proximity to the front of the engine. It's about a 2hr job.
yes it has a solid eaton coupler and all aluminum pipes and new water pump
when you open the oil fill cap while it’s running, you can hear the noise where the timing is through the oil fill cap.
Trouble is cars and especially engines are notorious for transmitting knocking/rattling/clicking/ticking/buzzing noises from the source/cause to somewhere else, so just because you can hear the noise through the open oil fill cap does not mean it's caused by the timing chain, it could still very well be a worn SC coupler.
