Coolant Leak - Experienced Advice Requested
Old Dec 23, 2025 | 07:55 AM
JagCode3's Avatar
@clubairth1 Any concerns about the steel tube pressed into the aluminum at that junction as you mentioned before? Seems like a possible point of failure.
https://www.jaguarforums.com/forum/x...3/#post2747722
Old Dec 23, 2025 | 08:03 AM
clubairth1's Avatar
Community Influencer
Nothing yet. This type of construction is very common in the car world and I have seen many examples. I would not worry about it and I have never seen or heard of a leak in that area either.
Since your interested in the rear water manifold I need to mention that there are 2 IDENTICAL electrical plugs at the back of the engine. This was a terrible decision and was not noted by JLR anywhere. It came to light when a forum member replaced the rear water manifold and started getting error codes. The rear water manifold has a temperature sensor in it. The Symposer also has the exact same electrical plug and yes they do plug into either one.
Note which plug goes to the rear water manifold. It does look like the Symposer plug is grey and the water manifold plug is black plastic.
This picture shows the water manifold temperature sensor location. The other hose shows the second engine coolant sensor. So there are actually 3 separate sensors that use the same identical electrical connection. Now there is no way you can swap the front and rear coolant temperature sensors because they are so far apart the wire won't reach.
But watch out for those 2 in the back of the engine!
Oh and do remove all that ridiculous Symposer stuff while your in there!
Old Dec 23, 2025 | 09:33 PM
dennis black's Avatar
Follow these Videos very old but get the job done for F-type, Xf, xj,F-pace
Old Dec 26, 2025 | 05:11 AM
Jejejbt's Avatar
Hello,
Where can I find the picture ?
Because on my car the 2 plugs are in the same color 😅
Old Dec 26, 2025 | 08:12 AM
RoverJoe's Avatar
The connector with the gray/green wires go to the symposer valve, the one with the yellow and white/brown goes to the engine temp sensor
Old Dec 26, 2025 | 08:19 AM
Jejejbt's Avatar
Thank you so much
Old Dec 26, 2025 | 09:18 AM
clubairth1's Avatar
Thanks for posting your picture. The other plugs I had seen were different colors. Yours are the same so very confusing.
Jp129
Apr 26, 2026 08:47 AM
Speedmaster
Dec 26, 2024 09:51 AM
Adventurous x
Jan 17, 2023 01:29 PM
lear60man
Jan 31, 2022 09:46 PM
Leo032
Feb 8, 2018 07:08 PM
