coolant pipe leaks: what years?
What year models had the plastic coolant pipes with the weak seams that occasionally failed due to heat? I'm thinking that Jaguar fixed the problem for 2015 models forward but I'm not sure.
Thanks!
Thanks!
Per forum rumors 2017 is around when the f type had the y pipe redesigned.
It’s worth replacing, when you get the chance, and while you have the sc out might as well replace the sc coupler and sc oil. This DIY is excellent.
https://www.jaguarforums.com/forum/f...-guide-241372/
