Creaky noise when pushing the clutch pedal
My car is getting close to 60K miles and when I push the clutch pedal there's a little creaky noise. Still works fine, but after all, its a Jaguar and there should be silence when clutching. Talking
Before I try going in upside down into the drivers footwell of my coupe to look at the top of the clutch pedal mechanical, I was wondering if anyone out there with a manual knows if there is some sort of spring (sounds more like a spring) or hydraulic assist mechanism at the top of the clutch pedal that could be the culprit.
I have a 2017 and have driven manual transmissions all my life. I am not experiencing this in my 2017, yet, at 43,000 miles. I would suggest getting some "dry lube' and applying it to the pivot point, working the pedal a bit and then seeing if the creak disappears. Be sure to protect the carpeted area in the footwell and the clutch pedal pad, so that you don't get any of the lubricant on those surfaces.
Had that noise as well at 34K miles, not all the time, normally on hot days and it wasn't bothering me too much. It turned up to be the cylinder master which is being replaced this week. The car is in for an engine replacement job so I've asked all clutch components to be checked, that's how I know.
But I agree with Valerie, start with a lubricant just in case it helps.
Your question prompted me to start this thread and share some knowledge about the 6-speed MT
https://www.jaguarforums.com/forum/f...bility-290161/
YOLO
I am currently training my teenager how to shift on the F-Type!
@WSHudds give us a status update on your car please.
I'm getting all new alloy pipes and water pump, oil cooler, belts, slave cylinder, 6 new injectors, practically a new car. Insurance/extended warranty only paid for 60% of a £17K bill but the ombudsman took on my case and is arguing with them.
