Cruise control missing
Old Oct 28, 2017 | 04:00 AM
Christophe's Avatar
Default Cruise control missing
Hi guys,
My F-type I bought doesn't have cruise control. Is it possible to install it aftermarket?
Thanks,
Christophe
Old Oct 28, 2017 | 08:04 AM
SinF's Avatar
This is unusual. I heard about bare-bones F-types, but only for sale in UK.
Old Oct 28, 2017 | 08:14 AM
Stohlen's Avatar
In BMWs they don't offer rear fog lights in U.S. spec models, but you can add it just by replacing the headlight switch with a European model switch. Perhaps adding the switch would also add the feature since it isn't that complex. Many times its cheaper to just take away the switch than make 2 different wiring harnesses/software packages that increase plant complexity.
Old Oct 28, 2017 | 12:26 PM
Christophe's Avatar
Well, the option was not selected when the car was bought new.
So where the buttons normally are on the steering wheel there is a plastic cover.
Old Oct 28, 2017 | 02:45 PM
Stohlen's Avatar
Correct. So you'd need to pop that cover off and see if there is electrical connections present underneath.
Old Oct 28, 2017 | 03:42 PM
OzXFR's Avatar
You will probably need a new steering wheel with CC (plenty available on Fleabay or from Rimmer Bros) and then you would need someone to tweak the CCF using SDD to turn the system on.
Old Oct 28, 2017 | 03:46 PM
Stohlen's Avatar
This is probably the most likely scenario, but its possible you don't need to tweak anything. Being there are no switches, the system could technically be active all the time without any issue. This would reduce plant complexity when initiating the vehicles.
Old Jun 9, 2020 | 02:13 AM
bcbruno's Avatar
Hi guys,
Thanks,
Christophe
I was also victim of this issue, only notice after.
Did you got to solve this issue?
Old Jun 17, 2020 | 01:34 AM
bcbruno's Avatar
Help!!!
Without Cruise control this car became a bit annoying on longer trips, my knee and foot got numb all the time...
I really need to find a solution for this perhaps someone can indicate a expert that might can solve this.
Arden told me they can only sell me the steering wheel but no coding the CC buttons....
Old Jul 28, 2020 | 04:02 PM
carlos CCO's Avatar
[QUOTE-bcbruno;2248952] ˇˇˇAyuda!!!
Sin control de crucero este coche se convirtió en un poco molesto en viajes más largos, mi rodilla y el pie se adormeció todo el
tiempo...
Realmente necesito encontrar una solución para esto tal vez alguien pueda indicar un experto que pueda resolver
esto.
Arden me dijo que sólo pueden venderme el volante, pero no codificar los botones CC....
[/QUOTE]
Hola,
Alguna noticia nueva sobre su duda, tengo el mismo problema.
Gracias
Old Jul 29, 2020 | 09:45 AM
eeeeek's Avatar
Side note: I hate rear facing fog lights. Why? Because every jackass with a Merc or Audit that has them drives around with them on ALL THE TIME.
Old Jul 29, 2020 | 10:29 AM
scm's Avatar
scm
In the UK they don't use them all the time, but at the first hint of mist - on they go to blind following drivers. And many of them think they're rain lights, which are really blinding. and not just limited to Merc and Audi - lots of idiots driving other makes.
