CTEK Charger - Help with Facelift Car.
Old Sep 3, 2024 | 02:12 PM
scz4's Avatar
Default CTEK Charger - Help with Facelift Car.
Hi guys,
Feels like winter is fastly approaching, certainly here in Scotland anyway and would like to start preparing the car as I have a long work trip coming up
I had a CTEK connected to my V6S, but my MY22 P450 has very different circuit\connectors. Does anyone have a diagram for the facelift car of where to attached the eyelets?
Thanks in advance.
Graeme
Old Sep 3, 2024 | 09:40 PM
WhiteTardis's Avatar
Just FYI...you can also use the alligator clips on the CTEK charger and clip to the jump points under the hood.
Old Sep 3, 2024 | 09:47 PM
Valerie Stabenow's Avatar
Not sure how much is different on your car..
https://forums.jag-lovers.com/t/usin...-tender/397617
Old Sep 3, 2024 | 10:19 PM
bjg625's Avatar
There are pics of how and where to connect pigtail connection
Old Sep 4, 2024 | 03:16 AM
scm's Avatar
scm
Can't you just follow the battery leads and find suitable (and similar) equivalent connection points?
Old Sep 4, 2024 | 03:49 AM
DMeister's Avatar
Originally Posted by scz4
Hi guys,
Thanks in advance.
Graeme
In case this type of setup might be of interest to you…This is what I ended up doing for my 2024, mainly because I always have my car plugged in when not driving in order to keep the battery optimal…For this reason I wanted things super convenient…
https://www.jaguarforums.com/forum/f...-setup-280537/
Old Sep 4, 2024 | 05:06 AM
Cluck's Avatar
Mine (an MY21 P450) is wired into the busbar in the boot as per below image. The negative is attached to the honking great earth bolt in the boot - you'll see a thick wire already attached to it
Been wired like that since I bought the car new in 2020.
Old Sep 5, 2024 | 11:49 AM
scz4's Avatar
Thanks so much for that. Will give it a go tonight.
Old Sep 5, 2024 | 01:46 PM
scz4's Avatar
Do you have any pictures of what earth you used?
My cable is super short and worried this isn't the right place for it? But since the hole is so small (6mm I think) I can't connect it anywhere else. Worried about reconnecting the battery though since it's effectively "earthed" to the same box". Also conscious it's through a painted bracket if that makes a difference??
Old Sep 5, 2024 | 01:50 PM
scm's Avatar
scm
If you plug the charger in and it seems to work, then you're good to go! If the earth isn't good enough the charger probably won't see a circuit and won't light up.
Old Sep 5, 2024 | 01:51 PM
scz4's Avatar
OK thanks. As long as I won't break anything then since it's effectively the same box.
Old Sep 5, 2024 | 03:05 PM
scz4's Avatar
For future reference for anyone who finds this thread, that earth point seems to be ok for now.
peterv8
Nov 14, 2024 11:46 AM
Defender99uk
Nov 6, 2021 11:41 PM
richzak
Jan 19, 2018 07:03 AM
tony bosco
Feb 13, 2015 05:05 PM
chazaroo
Feb 10, 2014 07:39 AM
