Dash vent stuck in open position
Old Apr 11, 2014 | 10:57 AM
thorton-1's Avatar
I had to have the whole vent assembly replaced on mine for the same reason. The dealer ordered the assembly in advance and I had the car back the same day I dropped it off.
There have been no creaks, squeaks or other problem.
Old Feb 16, 2020 | 02:34 AM
Watti's Avatar
Originally Posted by tai4de2
I noticed that when I turned off the ventilation system, the dash vent didn't close. Numerous ignition start/stop, cycling the ventilation system on/off, and changing the setting between "auto" and "always open" didn't fix it. Now it's stuck open.
That auto-closing vent mechanism has never inspired confidence in my particular F-Type. It would sometimes not open fully -- off by a couple of mm. Also I sometimes see some indication of wear on the raised parts near the vents, as if it was rubbing on something as it opened/closed. I bet it wasn't installed quite right originally, or is defective...
My concern is that the dealer will have to take apart the dashboard to fix it, and that the dash will never be tight and squeak-free again after that.
I still love this vehicle, but I am starting to feel concerned about how often it's been in the shop after just a few weeks of ownership. Lots of little things add up to the seeds of dissatisfaction. If the dealer wasn't conveniently located I would be seriously irritated by now.
Snap, my bloody vent is now stuck open too, I'd SORN the car for 4 months over the Winter, the battery was OK but I did have a couple of low status warnings when I ran it up in the garage for 1/2 HOUR. I've since re taxed the car and taken it out for a few drives, battery is now OK it seems but the vent is still stuck up. There is a clicking sound when it's wanting to lower like something has come adrift, you can push it back down manually and it does reopen smoothly upon startup again. I read it somewhere that the weather can make it stay down at times but it should retract all the time when the engine is turned off. The whole system is very confusing.
I just don't understand what the Default position is supposed to do, also the clear all ??? No mention in any of the Jaguar literature I have. Can anyone shed any light on the best settings, maybe leave it in Auto, high sensitivity, centre vent in Auto too. I'm hoping it'll start working as it should but I'm taking it to the dealer on Tuesday to get it looked at. Quite annoyed as it looks like it'll cost me a few hundred quid to sort.
Old Feb 16, 2020 | 05:03 AM
scm's Avatar
scm
I leave my centre vent set to auto, and I know when winter is approaching because it stops raising on start-up. You can set it to always raise, but as I understand it, the center vent only vents cold air, so no need for it when you want to warm the cabin (warm air rises so it would only heat the roof!). It does sound like you have an issue if it doesn't close when you switch off, though. It's a cool feature (literally, too!) but does add a level of possibly unnecessary complexity. Should be covered by warranty, if you have one.
BTW, if you store the car away for several months it's highly recommended to put it on a battery conditioner (CTEK, etc.) to maintain the battery - it will run down over 4 months and these cars demand a full battery to avoid any niggly electrical gremlins.
Old Feb 16, 2020 | 02:00 PM
Unhingd's Avatar
+1 to just leaving on Auto. Never needed to adjust anything other than temp. I turn the temp up just a bit in the winter when I drive with the windows down (most of the time).
Old Feb 17, 2020 | 01:18 AM
Watti's Avatar
Thanks for the Gen mate. I centre vent does blow warm air though. Anyway, does the vents work via a relay or mechanical device, I've seen a part on line that looks like a mechanism to raise and lower it but wonder if there's dome sort of relay to make it raise and lower, as I pointed out it raises normally but will not go down, there's some sort of clicking noise when it should be lowering and wondered if this was a relay behind the upper dash.
I was going to buy o e of those battery conditioners but unfortunately I did not get round to it. Maybe mine will start working again as normal when I've driven the car a bit.
Old Feb 17, 2020 | 05:16 AM
Scheffi's Avatar
Hi there, I´ve got the same problem on my 03/17 convertible. The outside-tempereture was about 10° and I was driving with open roof. For the first 10 km it won´t open completely.
After an hour everything was working again.
I´ve got the service in one month and ask the dealer about it.
In the german jaguar-forum is a solution for this. You have to loose a couple of screws, took the whole thing out and dip some oil onto the plastic shafts.
But not my problem, car is under warranty.
Old Feb 17, 2020 | 05:40 AM
scm's Avatar
scm
If it's under warranty they'll probably replace the whole unit. Much easier and cheaper than a couple of drops of oil.
Old Feb 17, 2020 | 05:55 AM
  #28
Watti's Avatar
Depends on costs, my extended warrantee ran out last June and the dealer wants £168 just to look at it, the Warrantee renewal is about £980 🙁.
If there's a link on how to loosen and get to these screws and oil the bits I'd be interested as it would save me somme ching ???? It may look nice but in practice the raising vent is ***** if it packs up all the time.
Old Feb 17, 2020 | 07:25 AM
scm's Avatar
scm
Have you considered trying a decent independent, they certainly won't charge £168 to look at it. If you give us an idea of your location, maybe someone can suggest a trusted local one. Once out of warranty I wouldn't let a dealer near my car!
Old Feb 17, 2020 | 07:41 AM
  #30
Watti's Avatar
Have you considered trying a decent inpedendent, they certainly won't charge £168 to look at it. If you give us an idea of your location, maybe someone can suggest a trusted local one. Once out of warranty I wouldn't let a dealer near my car!
In South West Birmingham England. I do know a place I've used before so I'll ring them up. Cheers 👍
Old Feb 18, 2020 | 02:30 AM
  #31
Scheffi's Avatar
Hi guys. Here is the link form the german forum with a youtube-video on its end.
Hope, it will help.
DIY Airvents
Old Feb 18, 2020 | 05:24 AM
  #32
Watti's Avatar
Default Centre Vent failure
Hope, it will help.
DIY Airvents
Thanks for all your help guys, unfortunately the vent was up the shoot and has had to be replaced. The cost has been £307 all in and with a 2 year part warranty, not to bad tbh. Just keep an eye on this as it is obviously a weak component.
razorboy
Aug 6, 2017 08:39 PM
dyna
Sep 28, 2012 08:04 AM
jahummer
Mar 7, 2011 07:48 PM
MattSteele
Jun 18, 2010 03:34 PM
jevs
Sep 29, 2009 06:32 PM
