Disappearing Coolant
Old Nov 17, 2017 | 01:48 PM
amcdonal86's Avatar
I wonder if I have a leaking waterpump! But I have a 4.2! I smell coolant on the outside of the car, and it appears I lose coolant at a slow rate. I have had the car pressure tested and the shop told me they left it hooked up to the pressure tester overnight and there was no loss of pressure?
I ordered a new expansion tank cap--I'll see if that does the trick?
Old Nov 18, 2017 | 02:31 PM
Mulmur's Avatar
When I had an XKR the pump 'weeped' a small amount of fluid and it really did not show up well on the pressure test. The master mechanic said it was a known issue and they replace the pump and that fixed it.
I recall he showed me that the pump was slightly wet at the bottom.
Lawrence
Old Jan 4, 2018 | 03:45 PM
15FTypeR's Avatar
Originally Posted by Jagged Wire
I took another long drive and got stuck in rush hour traffic. Despite replacing the water pump I could still smell some antifreeze. It wasn't as bad when I got home. I'm hoping its just some residue burning off. I'm going to keep an eye on it and check the coolant level often.
Any new developments? Still the smell?
Old Jan 7, 2018 | 12:21 PM
Jagged Wire's Avatar
Way better. I’ve been constantly checking the coolant level and its not disappearing.
Old Aug 12, 2019 | 07:12 PM
Jaggyx's Avatar
Had this same issue myself. Dealer replaced water pump and a few hoses after pressure testing. Luckily nothing under the supercharger.
Old Aug 23, 2019 | 07:04 AM
Miauuu's Avatar
Relevant post https://www.jaguarforums.com/forum/f...2/#post2116871
After a coolant pipe replacement I experienced sporadic antifreeze smell through air vents and heated plastic smell in engine bay. Originally I thought it was caused by residual coolant just burning off but dealer diagnosed a leaking engine oil cooler and thermostat housing. Water pump not leaking but dealer recommenced to replace with the improved one.
Old Aug 23, 2019 | 08:34 AM
Chawumba's Avatar
Low coolant level and sporadic antifreeze smell through air vents and heated plastic smell in engine bay after a coolant pipe replacement, Originally I though was coolant residue caused by the replacement of the pipe just burning off but dealer diagnose a leaking engine oil cooler and thermostat housing. Water pump not leaking but dealer recommenced to replace with the improved one.
Thanks for this - thought your dealer was nuts at first, but a oil to water cooler in the valley of the engine that leaks would explain the smell, perhaps the culprit in my car with the lingering antifreeze smell after water pump replacement. How long did your oil cooler swap take you?
Old Aug 23, 2019 | 01:57 PM
  #28
Miauuu's Avatar
Car is at dealer waiting for JLR to decide if I'll get some goodwill, if not I'll swap it. Can you check if yours leaks?
Old Aug 25, 2019 | 11:05 AM
Miauuu's Avatar
JLR will not offer goodwill so picking up the car tomorrow and will attempt the repair myself. I’m not 100% convinced the culprit is the oil cooler so I’ll add fluorescent dye and pressure & vacuum test.
Old Aug 27, 2019 | 01:46 AM
  #30
Mpowerr's Avatar
Originally Posted by Chawumba
Have same issue, smell coolant, had to add about 12 oz to the system, but no visible signs of a leak. Taking mine in next week. I'm told the water pump or small coolant tubes under the supercharger are likely culprits. Hope my local dealer is one of the better ones and can find the problem.
thats it. happened to me, and a tear in a hose.
Old Aug 27, 2019 | 05:00 AM
  #31
Miauuu's Avatar
What happened to yours? Water pump and a hose? Both? Or just hose? Which hose?
Ken2839
Oct 3, 2016 09:42 PM
showstopper9ren
Sep 13, 2016 04:50 PM
steveeasy
Jan 21, 2015 05:29 PM
switchspencer
Sep 26, 2011 10:07 AM
JVandenPlas
Jun 14, 2010 06:25 PM
