DIY P7-style open front grille
Old Nov 12, 2018 | 10:08 PM
Jaggyx's Avatar
Originally Posted by Unhingd
This is the OE P7 grille lol I wanted to see the OP's diy project completed and on the car.
Old Nov 12, 2018 | 10:23 PM
Tork Monster's Avatar
Great to see this!
I have been contemplating building a grill as well. There are a number of challenges, including positioning the sensors, making the tow-hook work, and filling the cut-outs left in the chrome surround after removing the crossbar, but that just means it will be more unique when completed.
Old Nov 13, 2018 | 12:07 AM
Unhingd's Avatar
Doh! Sorry for the misunderstanding.
Old Nov 13, 2018 | 12:15 AM
Unhingd's Avatar
Originally Posted by Tork Monster
Great to see this!
If you are building from scratch, leaving a hole in the surround for the tow hook should be a straightforward solution. However, filling the gaps in the surround left by the bumper will be a challenge to make undetectable. Positioning the sensors is not really a problem as long as they are similarly placed to the original and the face of the sensor is flush with or forward of the front of the grille. They can't be recessed, otherwise you'll get false positives.
Old Nov 13, 2018 | 08:55 AM
Jaggyx's Avatar
All good. Either way, really like the look!
Old Nov 13, 2018 | 09:45 AM
xdave's Avatar
I forgot about this thread!
The grille was completed and sent to the end user to install. He got it installed at a body shop rather than doing it himself, so I didn't get any photos of the install but I was shown the finished car over Skype and he was really happy with the fit and finish. I've sent an email to see if he has any photos of the car and if he is still happy with it and will post if I get them and permission to share.
It was basically as shown in post 6 in this thread but gloss black both surround and mesh. The holes where smaller than the OEM, so I had to cut out diamonds of 4 holes on each side for the parking sensor mounts, and then 3D printed a mount from Colorfabb XT-CF20 which were sanded and painted gloss black to match. I fitted the OEM sensor inserts/spacers, but the clip at the rear was part of my printed part, and they were heat welded to the rear of the mesh with a soldering iron tip.
I was concerned that the orientation of the two sensors that were moved from the cross bar to the mesh would be off such that they either wouldn't trigger correctly or would false trigger, but they were fine. The forward ones are not as important to align as the sides.
The installer cut out/joined two of the mesh holes to create clearance for the toe eye thread. Literally just cut out with pliers, but it was not really noticeable. The metal member behind the mesh was painted black to match.
Old Nov 13, 2018 | 11:25 AM
Jaggyx's Avatar
I'd love to tackle this, but I've never done anything with Fiberglass and don't think I have the know how to attempt this.
I don't know where to source a P7 front grille either. They have some ebay carbon fiber ones, but I'd really rather stay away from carbon fiber.
Old Nov 13, 2018 | 11:40 AM
  #28
eeeeek's Avatar
I started repairing my race bodywork back in the day out of necessity ($$$) and found that it really isn't that tough. All you need is the basic fiberglass kit (cloth, resin and hardener) and then something to make a form (I've used empty water bottles and even an egg to make 'blisters' for exhaust clearance). The form doesn't have to be perfect as sanding works wonders. Once the fiberglass is hard, you just use sandpaper to smooth it and correct shaping issues. If you got too far and burn through an area, just re-glass it. It's really pretty straight forward.
Old Nov 13, 2018 | 01:24 PM
Jaggyx's Avatar
Maybe I'll give it a go one day. And what about respirators? I know breathing that stuff in is bad business.
Old Nov 13, 2018 | 01:35 PM
  #30
eeeeek's Avatar
I just used a basic mask. You just don't want to breath in the dust from sanding.
Old Nov 13, 2018 | 02:06 PM
  #31
Jaggyx's Avatar
Cool - thanks. And what body filler would you use, if any at all?
Old Nov 22, 2019 | 12:00 AM
  #32
Meister_Kajo's Avatar
Hello people, I now have 5 pairs of adapters, which I can offer. If you are interested please contact me. greetings
Old Dec 16, 2019 | 01:47 PM
  #33
STMPY's Avatar
Do your adapters fit with the ebay honeycomb grill from the OP?
Old Jun 24, 2023 | 04:00 PM
  #34
powerhouse's Avatar
O
Old Jan 18, 2024 | 01:09 AM
  #35
reppe711's Avatar
Hey guys,
does anybody still have an adapter lying around? I have access to a 3D Printer and could scan & print them if needed.
Meister-Kajo wasn't online since 2021, so I don't think, we can get adapters or the file to do it.
Thanks a lot and best regards from Germany,
Tim
Old Jan 23, 2024 | 02:06 PM
  #36
Therock88's Avatar
Originally Posted by reppe711
Hey guys,
Tim
My adapter is installed, but I have the specs from various sources, including Unhinged...Maybe it will help?
DC
Old Jan 23, 2024 | 05:02 PM
  #37
Whalesmash's Avatar
Hey guys,
Tim
I uploaded the design here. Also put it on thingiverse, but I can't log in to that site right now for some reason.
https://cults3d.com/en/3d-model/vari...-jaguar-f-type
Old Jan 23, 2024 | 06:16 PM
  #38
DJS's Avatar
DJS
Thanks, I added it to my Dropbox F-type repository.
https://www.dropbox.com/sh/wgv3e86yc...glFoM3xOa?dl=0
mcphill
Nov 14, 2023 10:13 AM
wurldfamuz
Apr 9, 2020 12:36 AM
powerhouse
May 5, 2018 04:10 PM
paulyling
May 9, 2015 07:43 PM
FLITTER54
Jun 21, 2013 08:51 AM
