Door window seal out of position?
Old Feb 8, 2026 | 03:46 PM
FTypeInTheSun's Avatar
Default Door window seal out of position?
Has anyone encountered this before? The window seal has come out of place ( I believe ), but it's not possible to just "push it back in". Any ideas? I don't think it's right because when washing the car I do notice water coming in through that area.
Thanks in advance!
Old Feb 8, 2026 | 03:48 PM
Old Feb 9, 2026 | 08:17 AM
Carbuff2's Avatar
The 'lip' the seal attaches to is horizontal, on the inside. (Hope that makes sense)
You need to push the seal towards the inside of the car, then PULL it towards you (starting from the front side where it is in the proper position).
If you can't figure it out, post back and we will supply a video. Might help to unlatch the top, a few inches off the windshield header.
The little 3" section of the seal (visible towards the right in your first picture) falls away on our Jaguar, too. I think that the glass sticks to the seal and pulls it down, so I apply talcum powder to my fingers and coat the seal to make it less sticky.
Also we periodically clean the black residue off the side window glass.
Old Feb 9, 2026 | 11:36 AM
That explanation was VERY helpful, thank you so much! I think I've done what you suggested, but can't be totally sure. And if this was the intended fix, I think my driver side seals were also not right. The first picture below is the current state of the driver side seals, and the second picture below is the current state of the passenger side seals AFTER I pushed the lip that you mentioned back in. Hopefully you can see the difference to see what I'm talking about.
It would be really helpful if anyone with this car could post a picture of how the seals are supposed to sit so I can make sure mine match.
Thanks again for the help!
Old Feb 9, 2026 | 01:30 PM
Carbuff2's Avatar
Our (garaged-in-the-dark) F didn't lend itself to usable photos just now, but you appear to have gotten your wayward seal back into position.
I think my advice to clean the sticky residue off the side-glass is worthwhile.
Old Feb 9, 2026 | 01:41 PM
I think so too! Thank you again for your help! I'm wondering if I should "fix" the driver side ones to match the ones I pushed in on the passenger side...
Old Feb 10, 2026 | 07:28 AM
Carbuff2's Avatar
Seems as if that would help you sleep at night....
adenshillito
Jul 29, 2022 12:29 PM
CzechJag68
E type ( XK-E )
Aug 31, 2016 06:45 AM
kreyszig
Aug 10, 2016 06:53 AM
Stamford
Nov 10, 2013 10:20 AM
Dounraey
Apr 30, 2011 09:08 PM
