DRL dim on one side
Old Dec 22, 2021 | 03:30 PM
tfs's Avatar
tfs
Default DRL dim on one side
I got a 2019 F Type R and the DRL on the driver side is significantly dimmer than the passenger side. The service advisor said that jaguar won't let them replace it as long as the light itself is working, even though it's not working as intended. Curious to see if any others have has this issue with their DRL? Thanks!
Old Dec 22, 2021 | 05:05 PM
CJSJAG's Avatar
I would try a different dealer and see if you still get the blow off!!
Old Dec 22, 2021 | 05:06 PM
Therock88's Avatar
Have not had that issue. Mine are both consistently bright. No issues. I do not think it makes sense to not replace if it is not completely burned out?? That is just dumb. So if the car is accelerating, but sputters, it is still "running" so no issues right??
If the wheels roll, but wobble, they still roll...right? So if the lights were intended to light up at 5300K or 6000K, but they are dimmer...They are NOT functioning as intended!
If they want to play games like that, maybe pull the wiring diagram and put a surge through it to burn it all the way out...Then they are NOT working as intended
DC
Old Dec 22, 2021 | 07:02 PM
tfs's Avatar
tfs
Thank you guys!! Going to try talking to them again and reason with them. I’ll let you guys know if this gets more interesting/frustrating haha
tfs's Avatar
tfs
DC
yes exactly!!
Old Dec 22, 2021 | 07:08 PM
Jamal302's Avatar
Experienced this issue with a 2018, it wasn't dramatic, but one of those things I couldn't un-see after seeing it.
Dealer agreed to take care of it without too much fuss. Replacement headlight has been on order for about 3 months now though.
I'd press the dealer to make the replacement as the MSRP on the headlights is ~4K.
Old Dec 22, 2021 | 09:18 PM
Fireze22's Avatar
Had issues with the drl's on our 2020 F-150 King Ranch. They replaced both headlights, twice. Wasn't the issue. It was the control module.
Old Dec 23, 2021 | 10:20 AM
Sparky H's Avatar
Pls excuse my mucking up your thread, Sirs. I am "in the saddle" pushin cows down a mountain at 26 degrees F. What is a DRL exactly?
Sparky
Old Dec 23, 2021 | 11:05 AM
scm's Avatar
scm
DRL - Daytime Running Light
Old Dec 23, 2021 | 11:22 AM
Fireze22's Avatar
Sparky
If you're being serious, I'm very jealous right now. I miss those days... Probably seems crazy to you while you're in it, but when it's gone...you miss it.
Old Dec 23, 2021 | 11:34 AM
Carbuff2's Avatar
Instead of asking a dealer to replace the light, tell them you just want them equally bright.
Post 7 might have the answer...
Old May 20, 2023 | 04:08 PM
Ichi Ban's Avatar
It seems that it is now my turn to deal with 2018 F-Type DRL failure. Only one segment on the left DRL functions and the entire DRL on the right is dim. Not even 34,000 miles on the odometer. I never had a headlight issue with my previous 2015 & 2016 F-Type S' with HID headlamps. (Well, that is except I had to have a headlamp assembly replaced on my 2015 thanks to a stupid deer.) How much you want to bet that the manufacturer of the headlamp or control module had defects. If there wasn't a DRL problem with HIDs why would there be a DRL problem with the new LED headlamps? Hopefully, the extended warranty hasn't expired.
adrien78650
Sep 12, 2021 09:11 PM
cpq100
May 5, 2020 04:18 PM
MI-FType
Jan 12, 2016 08:09 PM
SteveSvr
Canada
May 6, 2015 05:23 PM
bklynchris
Jun 26, 2014 09:27 AM
