Dynamic Mode
Old Jun 12, 2018 | 07:33 AM
rexus31's Avatar
Default Dynamic Mode
On a non Active Switchable Exhaust equipped car, does Dynamic Mode change the exhaust note?
Old Jun 12, 2018 | 08:00 AM
uncheel's Avatar
Yes, and you should see the light by the switch on the center console illuminate.
Old Jun 12, 2018 | 08:39 AM
DJS's Avatar
DJS
That's assuming you have active exhaust, even if it's not switchable.
Old Jun 12, 2018 | 09:02 AM
rexus31's Avatar
How would I know if the car is equipped with Active Exhaust? Active Switchable is easy because there is a button. Any tell tale signs?
Old Jun 12, 2018 | 09:15 AM
DJS's Avatar
DJS
It would help if you'd put the year/model of your car in your signature. V6S/V8S/V8R have active exhaust standard, it was an option on the base V6. Not sure if it's standard or an option on the current base models.
Old Jun 12, 2018 | 09:55 AM
rexus31's Avatar
Aplogies, thanks for the info. I’m looking at a 2016 340hp. I’ll inquire with the dealer if it has Active Exhaust.
Old Jun 12, 2018 | 10:20 AM
DJS's Avatar
DJS
I'm told you can sign up for Topix for free short-term, and look up the VIN there. Should give all the options. I've never done it, but that's my understanding.
Old Jun 12, 2018 | 10:40 AM
rexus31's Avatar
Do you have a URL? The site Google is showing appears to be dealer facing and requires dealer related credentials to register.
Old Jun 12, 2018 | 10:42 AM
DJS's Avatar
DJS
Never tried it, someone else will have to chime in.
Old Jun 12, 2018 | 10:53 AM
rexus31's Avatar
Thanks. I used this site’s VIN decider tool for the car in question and one that I know has Switchable Actuve Exhaust. Both searches showed no active exhaust listing, Switchable or otherwise. Curious if this tool pulls from Topix.
Old Jun 12, 2018 | 11:13 AM
ek993's Avatar
If you have active exhaust but no switch, putting in dynamic mode will not change the exhaust note
Old Jun 12, 2018 | 11:17 AM
rexus31's Avatar
I think I get it. If a car is equipped with Active Exhaust, it is full time. Switchable Active Exhaust can be toggled on and off. Am I uunderstanding this correct?
Old Jun 12, 2018 | 11:47 AM
rexus31's Avatar
I was able to access Topix. The car in question does not have Active Exhsust. Thanks everyone!
Old Jun 12, 2018 | 12:54 PM
DJS's Avatar
DJS
Depends on what you mean by exhaust note. It makes a huge change on my car - in dynamic, you can hear the valves open in dynamic under load, and it gets loud. Doesn't do that with dynamic off.
Of course, since I pulled the fuse, it's always loud.
Old Jun 12, 2018 | 01:14 PM
tzoid9's Avatar
Interesting on the “pull the fuse” comment. I have an ‘18 F type R...does pulling the fuse leave the car in the loud mode all the time? What fuse number should be pulled? Does it set off any codes? Thanks!!
Old Jun 12, 2018 | 01:20 PM
ek993's Avatar
No. If you have active exhaust, but no switch the exhaust is quiet until you hit 4000rpm then the valves close (or open... whichever way round it is) and the exhaust gets noisy.
Putting in dynamic does not alter this behavior - for cars without the switch. For cars with the switch, putting in dynamic automatically switches the exhaust to noisy mode.
rexus31's Avatar
Does your car have Active Exhaust?
Old Jun 12, 2018 | 01:21 PM
ek993's Avatar
On the older models used to be F43. Not sure if that still works on the newer models, seem to remember reading a thread that indicated this is no longer possible.
Old Jun 12, 2018 | 01:41 PM
DJS's Avatar
DJS
Have to disagree - being in dynamic definitely makes a difference in exhaust sound. I have active exhaust, but not switchable active exhaust.
This applies to earlier cars; they got rid of the electric vacuum pump around MY16-17, and use engine vacuum instead. My pump and valves are noisy, which is why I pulled my fuse.
https://www.dropbox.com/s/szc3vze5ol...haust.pdf?dl=0
Old Jun 12, 2018 | 01:49 PM
ek993's Avatar
If you put it into dynamic, the exhaust goes into noisy mode 100% of the time from idle all the way through the rev range as I think that is what the OP is looking for - or only under load?
