F Type belt change
Old Dec 5, 2024 | 10:11 PM
Mogie's Avatar
Default F Type belt change
Hi
I have a 2018 R Dynamic and wondered if the supercharger belt and drive belt needs to be changed as it is 6 years old. Some opinions are that it is done at the 9 year service.
Thanks in advance.
Old Dec 6, 2024 | 04:18 AM
WSHudds's Avatar
I'm planning on having mine replaced as per the service schedule (9 years).
Old Dec 6, 2024 | 05:28 AM
DMeister's Avatar
Originally Posted by Mogie
Hi
Thanks in advance.
Car looks great man. Love that blue.
Old Dec 6, 2024 | 08:45 AM
Cvankeulen's Avatar
I have recently replaced both belts on my 2015 (70,000 km / 43,000 Miles) and the old ones looked surprisingly good. It made sense for me to do because i preemptively replaced many parts (spark plugs, coolant hoses to newer spec, waterpump, various other hoses/pipes). It will give you some piece of mind
Old Dec 6, 2024 | 10:26 AM
samit's Avatar
My original accessory drive belt was in excellent condition after 9 years, so I postponed the replacement until year 10. I finally replaced it a month ago and the belt had zero cracks, no visible wear, and was just as flexible as the new one. YMMV, so I would recommend just following the factory maintenance intervals.
Old Dec 6, 2024 | 10:37 AM
Evoex's Avatar
Year 9 for me is 2025, will likely do the same as @Cvankeulen and just go nuts with preemptive replacements while i'm in there.
Oh I just noticed you`re also from Toronto. /wave
Old Dec 6, 2024 | 10:45 AM
DJS's Avatar
DJS
My S/C belt was replaced when I had the S/C coupler replaced. But I think I still have the original accessory belt, one more thing to add to the list for next spring, along with tires and transmission fluid change. Maybe brake bleed and spark plugs too…
Old Dec 6, 2024 | 12:19 PM
WayneB's Avatar
I just got done replacing both belts last week on my 2014 V8S (Very Low Miles though) during it's 10 year service along with : Aluminum Y Pipes, Aluminum Rear cross over pipe, water pump, spark plugs, fluid changes and a bunch of other things and the belts looked like new. So, I put them in my trunk just in case I should ever throw a belt in the middle of no where and need one where they are not available.
Old Dec 6, 2024 | 12:26 PM
Cvankeulen's Avatar
Nice! Already found a garage for your services? I had everything done at Westminster Motors (Jag-specialist), I can definitely recommend!
Old Dec 6, 2024 | 12:34 PM
Evoex's Avatar
Using an indy near me that i found on these forums - Berkshire Automobiles. Jose and his team are doing well so far..
Aarcuda
23
Sep 17, 2024 05:39 PM
dougxk
Sep 5, 2023 02:27 PM
Dave Redline
Mar 27, 2021 09:21 PM
Mike198
Jun 16, 2017 12:51 PM
