F-type issues
Old Aug 8, 2015 | 05:27 PM
barcers's Avatar
Default F-type issues
I have a 2016 model V6 340hp Coupe in glacier white, with many bodywork issues... All plastic body parts do not match the aluminium painted areas noticeably. The local Jaguar body shop tested the colour difference and my warranty agreed to repaint the plastics to match as it was agreed the difference was unacceptable. My experience was poor with the local body shop.... only the front nose cone was painted, they damaged my dashboard and their driver ripped the **** out of my car when returning it... incontrol app was invaluabe for catching the ****** out. Has anyone else had the same issue with Glacier white??
Other issues: my bonnet and drivers door are not aligned with car lines / styling. The bonnet encroaches into the wheel arches on both sides, the drivers door lines do not match up with the rear quarter lines, anyone else experienced this?
I absolutely love my car, however it now looks like I will have to reject the car and get a new one ordered, which is not how I wanted my first Jaguar experience to go, however I have to commend my local dealer (Peter Vardy Aberdeen), as they have been very supportive and proactive.
I want to order my car in Glacier white again (believe me it is stunning in glacier white), but will need to have faith Jaguar have resolved the paint issue before I go ahead with order.
Anyone else had paint, body work issues to the point of rejecting the car??
P.S. its good to be bad 👍
Barcers
Old Aug 8, 2015 | 06:10 PM
TwiztOG43's Avatar
Do you have pics of these issues?
Old Aug 8, 2015 | 06:17 PM
Mulmur's Avatar
My F type is the R in Italian racing red and the paint and all trim are perfect.
The car overall has no issue whatsoever, as has my XKR.. no issue.
I hope you can get the paint and fitment worked out so it does not distract you from the fun of driving these beasts and with some persistence I'm sure Jaguar will look after you... I know my dealer and overall experience with Jaguar has been very good.
Lawrence.
Old Aug 8, 2015 | 07:34 PM
lizzardo's Avatar
My '16 is Storm Grey, and perhaps because it's a new "premium" color, it all seems to match. Haven't washed it yet though. That's when I'd be most likely to notice discrepancies.
Old Aug 8, 2015 | 10:07 PM
99Gsp's Avatar
Lawrence.
I also have IRR andI have no issues with the fit and finish . The paint match is right on. I rust your issues will be resolved. Do you know if there might have been any pre delivery repair or done that may have had an impact on the issues?...no pun intended
Old Aug 9, 2015 | 12:14 AM
shift's Avatar
the bonnet/hood might be a simple fix. sometimes it doesn't close properly. my had issues, the dealership fixed it in a couple of hours.
Old Aug 9, 2015 | 01:37 AM
barcers's Avatar
Here is my car in glacier white. P.S. Italian Racing Red was a close second choice!!! But may be my first soon. Notice the colour difference on the rear spoiler area.
Old Aug 9, 2015 | 01:44 AM
barcers's Avatar
Default pics
I will post pics, however the local body shop have realigned the doors (both sides, when only one side needed aligned!)but all they were able to do was move the problem from the top of the door to the bottom. Not their fault though, best they could do with the materials they have to work with. They made a great job of the front nose cone painting, but didnt put the nose cone back on perfectly....
And here is the dashboard damage 😠
Old Aug 9, 2015 | 02:23 AM
mshedden's Avatar
A UK Firesand coupe owner had a similar problem which I believe was fixed by the factory repainting (eventually):
https://www.jaguarforums.com/forum/f...erence-130501/
Old Aug 9, 2015 | 02:49 PM
Tel's Avatar
Tel
Yep, had paint quality and bodywork issues on a MY15.
Rejected car, replaced with new one, MY16, absolutely spot on. All issues inc stereo and other faults evident with earlier cars seemed to be ironed out.
Old Aug 9, 2015 | 03:44 PM
bjg625's Avatar
Stratus ,no problem. Had chip issue repainted and perfect match.
Old Aug 9, 2015 | 04:44 PM
F-typical's Avatar
Front bumper mis-aligned (prior to delivery, dealership fixed it but reported that it was now at the limit of adjustment), bonnet pretty much as pictured on your car addressed by JLR approved body shop, doors sticking out along the bottom edge addressed by the same bodyshop some months later. Front wheel arches still not ideal...
Old Aug 10, 2015 | 02:15 PM
DJS's Avatar
DJS
An improperly closed bonnet (hood) causes lots of seams to not line up. If you slam it with your hand from one side or the other, it will almost certainly latch crooked.
Two approaches to close the bonnet. Lower the bonnet most of the way, then stand in front of the car, and push down on the bonnet with a hand on each bonnet vent. Or, stand to the side, and reach out to the middle of the hood and slam down. (Think there's a video on here somewhere of the first technique.)
This typically solves some of the uneven lines.
Wolfy
May 28, 2024 08:06 AM
slojotaa
Oct 16, 2019 10:22 AM
JagBrian
Aug 18, 2019 05:07 PM
Aus V8S
Nov 13, 2015 11:01 AM
dcvickers
Sep 2, 2015 06:14 PM
