F Type S exhaust burned a hole in paint on rear bumper
Old Dec 19, 2021 | 07:40 AM
davidmaria1's Avatar
Originally Posted by SVR 575
Looking at that exhaust I don't think there is any question that the car is running lean, but I could be wrong. No codes, lean condition, what can it be?
I'm not sure on Jaguars, but in my experience, sensing rich, running lean to compensate, usually leads to a vacuum leak that won't set a code. Running a fuel trim map may help verify this, a basic obd dongle to a laptop. Or I may be in the stone age...
Old Dec 19, 2021 | 09:20 AM
WestPalm83's Avatar
I have the dealer software. I will put it on the lift sometime this week. ill see what the computer says. ill also check the plugs and measure exhaust temps at that time. i hope i find the smoking gun
Old Dec 19, 2021 | 11:05 AM
SVR 575's Avatar
Let us know for sure, I'm sticking with an O2 only because a MAF would have both banks running lean, and I just can't see a whole bank of FI's clogged at the same time, and that heat sure as phuq isn't caused by one injector spraying weak, but I could be wrong on all counts.
Old Dec 19, 2021 | 11:08 AM
SVR 575's Avatar
Stone age thinking might be spot on
Old Jan 18, 2022 | 07:48 PM
WestPalm83's Avatar
Sorry for not getting back to posting the results. I got stuck in Mexico for a few weeks.
Anyway, after a 45-minute drive, I measured the exhaust temps of the exhaust tips (107 & 110), and manifolds (355 & 350). Both sides were within 5-10 degrees of each other. The bumper felt cool tho the touch. I also did the OBD scan and it came back with no codes. I also pulled the spark plugs on the passenger side and they looked good.
Old Jan 18, 2022 | 09:01 PM
SVR 575's Avatar
That ground electrode looks like it has some white deposits on it. The only way to truly read EGT is to install a probe just past where the header collects the pipes into one, and then connect that to a guage you can read while driving.
Old Jan 19, 2022 | 06:53 AM
WestPalm83's Avatar
I went back and looked at the pictures of the plugs and compared them to charts I found online. It's definitely running lean. Now it's got me wondering if it only happens when I'm at high speeds and it's a fuel delivery issue or if it's happening all the time due to a o2 issue. I might pull the plugs on the other side to check those as well. I hope I don't have to take it to a shop to fix this issue
Old Feb 3, 2022 | 09:08 AM
  #28
WestPalm83's Avatar
Well, I decided to take the car to a shop to have some diagnosis done that I wasn't able to do. They were not able to find any issues and they think that it is a result of driving the car hard.
Old Feb 3, 2022 | 11:32 AM
uncheel's Avatar
I call bogus on the "driving hard" response. Otherwise, there would be a fleet of us on the board with peeling paint. Assuming you've checked spacing, as mentioned above, I'd lean toward a factory paint defect. Repaint and move on.
Old Feb 3, 2022 | 12:31 PM
  #30
My guess would be some object or substance that would ignite at the temperature of the exhaust tip.
Old Feb 3, 2022 | 01:41 PM
  #31
Mahjik's Avatar
Since the valance has already warped from heat damage, it'd be surprised if you didn't need to replace it. That being said, I would look at lowering the exhaust a little. Doesn't need to be a lot, but about an inch would likely give you enough clearance from the valance where the heat won't be an issue.
Chris63
General Tech Help
May 24, 2021 08:11 AM
jeff_the_chef
Jun 30, 2020 06:51 PM
Philipintexas
Dec 20, 2015 12:01 AM
randyb
Sep 30, 2012 03:07 PM
Bull27
26
Mar 12, 2010 02:04 PM
