"Lace" like film on the rear bumper
Old Dec 17, 2015 | 03:52 PM
Philipintexas's Avatar
Default "Lace" like film on the rear bumper
Just washed my red F-Type and noticed a barely visible lace-like film on the paint surface, obviously from exhaust residue that is pulled into the low pressure area and settles on the rear bumper. It's only visible with the right light. I washed it and it wouldn't come off, tried a quick detail spray with no effect. Then tried wax, absolutely doesn't touch it. Is there something that will remove this discoloration from paint? I can only imagine the chemical concoctions produced by burning today's gasoline and it sure appears to damage paint. Is this the result of "Acid rain"?
Old Dec 17, 2015 | 07:23 PM
Unhingd's Avatar
Have a good detailer look at it, and consider having the surface cQuartzed to protect it from further damage after the issue has been corrected.
Old Dec 18, 2015 | 10:11 AM
XJL's Avatar
XJL
Can you post a high resolution picture?
Old Dec 18, 2015 | 10:24 AM
Foosh's Avatar
I have doubts that it's from exhaust residue, but I do agree that whatever is on the road gets sucked into that low-pressure area. It's more likely from something you ran through on a road surface at some point.
Old Dec 18, 2015 | 11:02 AM
TXJagR's Avatar
Totally in agreement here. 13,000 miles on a 2016 R and I have nothing like you mention on mine...
Old Dec 18, 2015 | 11:37 AM
Unhingd's Avatar
+2. Colorado uses a clear road sealant that is sprays on the interstates. I was about 1/4 mile behind one of the spray trucks that was leaking and ended up with that clear gunk all over my '84 Vette. Had to use mineral spirits to remove that cra$.
Old Dec 18, 2015 | 01:35 PM
deltagroup's Avatar
Don't think it's exhaust residue either. And not the place for acid rain spotting, which usually shows up on horizontal surfaces like the hood, roof or trunk area. (Acid rain leaves residual rings or shallow spotting (in its more severe form) from the dried-up rain droplets.)
Your lace-like film could come from any number of road contaminants, but your comment that there is discoloration adds another possible level of concern. Good thing you're attending to the matter promptly. What do you feel when you move your hand over the area? Is it smooth or rough?
A good pic might help or not. Pretty difficult to diagnose with seeing the patient. Washing, detailing and wax are "light-weight" corrections at best. You or your detailer will likely have to go more aggressive to cut/remove the contaminants. Keep us posted.
Old Dec 18, 2015 | 05:06 PM
StealthPilot's Avatar
Sounds like a mineral deposit.
Amazon.com: Eraser Water Spot Remover 16 Oz - Gel: Automotive Amazon.com: Eraser Water Spot Remover 16 Oz - Gel: Automotive
Old Dec 18, 2015 | 05:13 PM
DuhCar's Avatar
Old Dec 19, 2015 | 11:24 AM
It's very difficult to see much less photograph. I can only see it when the sun is near the horizon behind the car. The low light reflects upward off the bumper and I can see it. Direct light and I don't. The closest thing I've seen is a glass shower door that has not been cleaned for a while. Dried water spots leave a residue that is difficult to remove. The car is garaged and rarely wet however goes long periods without being washed. I even tried "Scratch-off" to no avail.
Thanks for the suggestions, I'll keep trying.
Old Dec 19, 2015 | 11:59 AM
SoCalJagS's Avatar
Have you tried detailing clay?
Old Dec 19, 2015 | 04:01 PM
Unhingd's Avatar
Is it the entirety of the rear bumper? Does the problem extend to the rear panel or fenders. How soon after the car was munufactured did it get coated or waxed?
A similar thing happened to me with the passenger door on a '70 280SL and the right side headlight cover panel on an '84 Corvette. The paint on those panels wasn't cured properly. Both were covered under warranty. You'd think QC would be better these days, but…
Old Dec 19, 2015 | 05:26 PM
OzXFR's Avatar
Yep, I would try using a clay bar or clay cloth on it.
I have used Dodo Juice clay bars in the past with great results, Bilt Hamber also make a good one.
Old Dec 19, 2015 | 11:30 PM
SoCalJagS's Avatar
I've never heard of Dodo Juice brand. I use Adams, they make excellent detailing products too.
Old Dec 20, 2015 | 12:01 AM
OzXFR's Avatar
Dodo Juice home page: Dodo Juice - Home of handmade car care.
I love their products, real top quality stuff.
My favourite is Born Slippy, designed as a clay bar lube, but it's a fantastic all-purpose cleaner. I've tried literally dozens of things to clean my computer and TV monitors but this is the only stuff I've ever found which gets them totally smear free and crystal clear.
bocatrip
Dec 14, 2015 10:54 AM
black_prophet
Dec 2, 2015 10:47 PM
Fstbmw1
Nov 27, 2015 03:08 PM
sandmann62
Nov 24, 2015 10:56 AM
quicksilvr20
Nov 20, 2015 09:10 PM
