F-Type SVR Discussion Thread
Old Jul 14, 2021 | 08:56 AM
  #881
(Not Mick) Jaaaagger's Avatar
Default Car Show Surprise
This one’s not mine (I have a sportbrake), but I thought you guys might appreciate it. Ran into it at a car show over the weekend.
Old Jul 14, 2021 | 09:19 AM
  #882
Jaguar1611's Avatar
Wow, I love the side Jaguar decal and silver/blue center wheel caps.......but the wheels and center striping!!! YIKES
Old Jul 14, 2021 | 12:47 PM
  #883
Yeah I’m not fond of the garishness. I think they were going for “Hot Wheels chic.”
Old Jul 15, 2021 | 06:50 AM
  #884
Jaguar1611's Avatar
anyone on here with a White SVR red interior in the Western New York area? I keep seeing one!
Old Jul 15, 2021 | 03:44 PM
  #885
Xec's Avatar
Xec
Should be illegal what they did to this poor SVR...
Old Nov 22, 2021 | 03:27 PM
  #886
Shei's Avatar
Default Straight pipes’ SVR video - Pops on command!
Hi guys,
I just came across this video and it brought a big smile on my face (picking up my 18 SVR on the 30th!).
- https://youtu.be/nPkpntQOn5U
Now I’ve a question, about 8:50 into the video they show a way to have continued pops and bangs from the exhaust - my question, are there any downsides doing this?
- does it hurt the engine, the exhaust, or does it just eats away fuel? 😅
I look forward to hear your insights, and if you didn’t know about it (and it isn’t harmful) you’re welcome 😜
Old Jul 13, 2022 | 06:07 PM
  #887
kb58's Avatar
Though I'm not in your elite group - only owning a lowly F-Type R, I thought I'd toss you guys a cookie. I had stopped in at the Jag dealer in San Diego for some parts and saw this on the way in. What you see is it, no price but appears to be a 2017, but if someone here is hard up for an SVR, keep your eyes on their website, as I'm sure it'll pop up eventually. Did one of you trade in one in San Diego?
Old Jul 17, 2022 | 01:29 PM
  #888
jaguny's Avatar
I have the only 2018 white SVR with red interior in the USA. II am in central NY. I know where the only 2017 is in that color combo (Maine), so there is only a 2019 and a 2020 somewhere. Info per F type Registery..
Correction, that color combo with carbon ceramic brakes.
Old Aug 3, 2022 | 10:55 PM
  #889
enigma55's Avatar
Originally Posted by Ftyperegistry
Thanks for the pics and Congrats! There are not that many Black SVRs with red interior. Yours might be the only one or one of only a few for the US.
It's crazy there aren't many since it's a $2500 upgrade on a 130k plus car but everyone drew the line there. LOL
Old Aug 25, 2023 | 08:34 PM
  #890
M3 Wrath's Avatar
Has anyone with an SVR upsized their tires? I was thinking of upping fronts from 265/35/20 to 275/35/20, and the rears from 305/30/20 to 315/30/20, keeping the profile percentages the same, which would result in slightly more rubber to fill the wheel well. Just wondering about any ill effects or potential problems.
Old Oct 31, 2023 | 08:58 AM
  #891
tomkinsong's Avatar
I'm a month in to owning my 2017 SVR. One thing I noticed when looking around the car after purchasing it was the accumulation of small gravel and other road debris that seemed to collect in bottom of the SVR front fenders - to the point where it pushes the fender out a little. I'd like to remove the outer panels an clean this up. I can see at the top there are just a couple of bolts but I don't know how they're fastened at the bottom. Does anyone know how to remove them?
Old Nov 1, 2023 | 05:51 AM
  #892
noochftype's Avatar
Good morning, about a month ago I picked up a 2020 SVR convertible white with a red interior. For the little bit I've driven it, what a great car!!! I had to put it in the dealer shop to have a little molding repaired under warranty and when they went to put it on the lift they cracked the body panel just in front of the driver side rear wheel well. They of course are repairing it free of charge but it's pretty annoying. Can't wait to get it back.
Old Nov 3, 2023 | 08:22 AM
  #893
BigJay13's Avatar
You have to go through the front wheel well. Remove the bolt and pull the inner wheel well out of the way. Look down into the area down the fender and there will be two (2) 10mm bolts/nuts that need to be loosened up or taken out, your choice. Once done, you can gently pull the lower part of the fender out and the rocks will drop out. If you want to take a second to clean and polish this area, now would be the time to loosen the 2 upper bolts and remove the panel. Once you are done, just put the panel back in place and tighten the nuts back up. Remember to push the fender back in while you do this or it will stick out too far and trap bigger rocks. It will also rattle when you go down the road. (Ask me how I know!!)
BE CAREFUL NOT TO BREAK THE BOLT IN THE WHEEL WELL!! It is very easy to snap off and a pain to repair. Good luck and I hope this helps.
Old Nov 3, 2023 | 02:18 PM
  #894
tomkinsong's Avatar
Thanks BigJay, really appreciate the advice. This might seem a little off the wall but I was wandering if the area between the fender panels had some kind of protective coating when the cars were shipped from Jaguar. Let's put it this way, the drivers side on mine most certainly has "something" stuck to the inside fender when I look down into it from the top with the two bolts removed. I'll grab photos when I take the outer fenders off.
Edit: forgot I had taken this photo (driver's side)...
It's not crazy clear but the black plastic at the bottom left is the wheel well liner with the vents. The green material looks tucked under that and is stuck to the panel all the way down. it's obviously coming loose on the "exit" through the back of the opening.
Old Jun 11, 2024 | 09:03 PM
  #895
dbleoh7's Avatar
Originally Posted by Grendeldad
This is SVR convertible with carbon package and brown top. Received it last October, drove it through the winter using SottoZero snow tire on standard F type wheels.
SVR with snow tires. A second set of generic F type rims was ordered with the care - shown here - to allow winter tire fit.
SVR with carbon package.
SVR with carbon spoiler.
Do you still have this car?
Old Jun 11, 2024 | 11:14 PM
  #896
Ftyperegistry's Avatar
I don’t think he does. I posted about this car in the SVR Production numbers thread recently. I saw it listed for sale last month post 641
https://www.jaguarforums.com/forum/f...3/#post2748760
Old Jun 12, 2024 | 08:37 AM
  #897
dbleoh7's Avatar
That's unfortunate. I've been on the lookout for firesand, ultra blue and BRG convertibles in the US. Not sure how I didn't see it for sale since I have alerts on Cargurus and Autotrader.
beatboy77
Feb 28, 2024 03:49 PM
Cambo
Jul 9, 2020 07:12 PM
Johnny Mayday
Nov 2, 2017 05:12 PM
Jaguar Forums Editor
Aug 19, 2016 03:54 PM
Dremorg
Jun 22, 2016 09:51 PM
