Faulty codes after changing battery
Old Nov 13, 2022 | 09:59 AM
mohammed m's Avatar
Default Faulty codes after changing battery
Hi guys
i have ftype v8s 2014, i changed my battery 2 weeks ago (aftermarket cheap battery with oem same spec) then Check engine light appears, i went to car shop to check my car by OBD and i got these faulty codes :ECM (Engine Control Module)
U0447-00 Invalid Data Received From Gateway A
ATCM (All Terrain Control Module)
2^
U0121-00 Lost Communication With ABS Control Module
U0294-00 Lost Communication With The Powertrain Control Monitor Module
GWM (Gateway Module)
B13C5-92 Secondary Battery
any help?
Old Nov 13, 2022 | 10:41 AM
DJS's Avatar
DJS
I’d be sure to put the battery on a charger, and charge it to 100%. Then see if the codes go away.
Old Nov 14, 2022 | 04:16 AM
mohammed m's Avatar
Its a new battery yesterday i checked all fine
790A
100 Ah
Old Nov 14, 2022 | 05:58 AM
DJS's Avatar
DJS
New batteries are rarely charged 100%. If you search the forum, you’ll find dozens of threads about codes being cleared by charging the battery (even a new one.)
It’s also easy to do, and it eliminates the most likely culprit if the codes don’t clear.
Old Dec 21, 2022 | 11:14 AM
mohammed m's Avatar
I tried every possible thing
how to charge the battery?
u mean the main battery or sec battery?
Old Dec 21, 2022 | 01:08 PM
sov211's Avatar
The secondary battery only relates to the start/stop mechanism. It is correct that new (main) batteries are almost NEVER fully charged. The codes showing all relate to battery voltage in an indirect way. So first, charge the main battery fully. And then, as DJS has stated you will likely find that the problems disappear.
A battery maintainer a very good idea for cars like ours which require full voltage all the time.
Old Dec 21, 2022 | 01:26 PM
mohammed m's Avatar
Ty for ur reply
i will try cuz the check engine sign disappear for 3 days then comes again
i will try to charge the battery
Old Dec 21, 2022 | 10:38 PM
DJS's Avatar
DJS
The easiest way is to connect a charger or battery maintainer to the jump terminals under the hood (I.e. near the engine.)
Old Dec 22, 2022 | 10:57 AM
Valerie Stabenow's Avatar
Default Buy the maintainer, no worries!
The suggestions here to buy a maintainer are ones you should strongly consider. Yes, you may have purchased a new battery, but as others wrote, the battery may have sat on a shelf in the parts dept. before being installed. My personal recommendation, is for the CTek unit that is a very popular choice on this forum:
Amazon Amazon
This Ctek unit assesses the battery and takes it through a multi-step process to bring it to full charge. It has the capability to charge an AGM battery as well as a 'standard' battery. It also comes with alligator clips or the eyelets, depending on how you want to install it. I chose to use the eyelets and leave the connection section of the wire in place in the trunk of my F. There are many comments on if and how you should close the trunk/hatch lid on the length of wire. My tech said to just press the lid down and then lock the car and it will think that everything's good and not stay 'awake'. That is what I do every winter, or in extended periods of time when the car isn't driven.
There are also MANY other threads on suggested chargers/maintainers. This one isn't cheap, but as with most things, you get what you pay for. There are also threads you can read along with photos of how others have chosen to connect.
Old Dec 22, 2022 | 03:21 PM
dmchao's Avatar
Did you reset the BMS? Disconnect the ground for like 30 seconds.
Charging is good advice as others mentioned.
Old Dec 22, 2022 | 03:33 PM
mohammed m's Avatar
Ty for reply
how to reset BMS any steps to follow?
Old Dec 22, 2022 | 04:57 PM
Default This should help
Here is a complete post with instructions:
https://www.jaguarforums.com/forum/x...change-241034/
Old Jan 25, 2023 | 08:51 AM
mohammed m's Avatar
ty guys for responses
unfortunately the check engine appears again with faulty codes shown above.
i change the battery to varta brand AGM same spec
recharge the battery to 100% the check engine cleared for 2 days then appears again
Old Jan 28, 2023 | 01:05 PM
mohammed m's Avatar
Any help 🥲
Old Jan 28, 2023 | 02:20 PM
sov211's Avatar
The Check-engine-light can be related to a number of things. Perhaps you can get a new readout of current codes (or have you already done that, cleared the codes, and checked again?) - that will tell you where the problem lies, now that low battery voltage (which would confuse the issue) has been eliminated. The CEL often relates to a faulty fuel injector or a faulty oxygen sensor. If it is the latter, please note that this is covered by a 15 year warranty in Canada and the US.
So using the code reader again will likely help solve the issue.
Old Jan 28, 2023 | 05:33 PM
Borbor's Avatar
You should have your alternator checked. With a fully charged battery everything is perfect. As your battery runs down the low voltage causes the gremlins to come back until you have charged up the battery again. Your car is obviously not recharging your battery as you drive around.
Ftypenate
Oct 17, 2022 06:31 PM
Sprite
Jan 12, 2021 02:42 AM
Andrew Steven
Dec 3, 2017 02:58 PM
03Xtype
May 16, 2016 09:57 PM
AlZee
Nov 7, 2011 10:42 PM
