First F-Type Oil Change @ 1500 miles--Lessons Learned
Old Jan 24, 2015 | 12:09 AM
  #41
deltagroup's Avatar
Originally Posted by abedh
"...As for oils, make sure you get an oil that meets the spec. It does NOT have to be Castrol.
Agree that the oil does not have to be Castrol. Other than Castrol though, what other oil carries the WSS-M2C925-A spec? Please share.
Old Jan 25, 2015 | 07:03 AM
  #42
mshedden's Avatar
Motul makes one, but may be even harder to find in the US than Castrol...
https://www.motul.com/system/product...pdf?1342446301
Old Jan 25, 2015 | 10:56 AM
  #43
deltagroup's Avatar
Good to know. Thanks!
Old Jan 25, 2015 | 11:07 AM
  #44
Unhingd's Avatar
WSS-M2C945-A is replacing the WSS-M2C925-A spec (Ford established specs). 5W-20 grades of full synthetic oils (not blends) from Castrol, Valvoline, AMSOIL and Mobil-1, all meet this spec. and are readily available at auto part stores.
Old Jan 25, 2015 | 01:54 PM
  #45
deltagroup's Avatar
Would you please share how you know C945A is replacing C925A? I'm no authority on oil, but I've found no persuasive authority that validates the equivalency of both specs. If Jaguar reissued its warranty-specified C925A spec for the 5.0L to C945A, things would be easier as many oil manufs carry the C945A spec.
Lots of varying opinions out there on the C945A and C925A specs. For example, check out this XF/XFR thread for a bumpy ride of varying opinion on C925A : https://www.jaguarforums.com/forum/x...tic-oil-95827/
Old Jan 25, 2015 | 04:49 PM
  #46
Mulmur's Avatar
Nothing to taking the cover off and replacing too. "Rubber grommet-over-stud" is a common fitment for engine covers these days. I have the "R," though I would expect to see a similar design for the other motors.
Just place your hands on the cover (on either side), equally spaced apart, and gently lift to release the two grommets on that side. Move over to the other side and repeat to release the other two grommets. Four in total. Cover comes off easily. To reinstall, I simply place my hands around the "J" and the "R" on each side of the cover and gently press to ensure all 4 grommets are properly seated. If you have the cover positioned correctly, you'll feel the grommets reseating themselves.
The pics show the grommet-stud locations. Pretty difficult to break anything. No plastic clips, i.e., no little PITAs to worry about). But, when you replace the cover, be sure you have the cover correctly aligned over the various cover cutouts (especially on the passenger's side) before pressing down on the cover.
Attachment 105008
Attachment 105009
Attachment 105010
Attachment 105011
Attachment 105012
I took my cover off a while ago.. for reducing heat..
Lawrence
Old Jan 25, 2015 | 08:02 PM
  #47
Unhingd's Avatar
Look at the data Redline data sheet (link below). Data sheets from other manufactures will confirm. WSS-M2C925-A specs conform to GF-4 specs. WSS-M2C945-A conforms to GF-5. GF-4 specs are less rigorous than GF-5. Any oil conforming to the latter meets or exceeds all of the specifications of the former. The top synthetic oil manufacturers don't bother to carry multiple spec grades. They will generally blend to the most rigorous specs they economically can.The top manufacturers are now blending to GF-5.
Red Line Synthetic Oil - Motor Oil - 5W20 Motor Oil
This histogram shows the relative difference in performance parameters:
Old Jan 25, 2015 | 09:24 PM
  #48
deltagroup's Avatar
I appreciate your effort here. I should have worded my question better.
My concern is not whether C945A is more rigorous than C925A (to which we both appear to agree), but whether Jaguar has acknowledged C945A in place of C925A for use in the F-Type 5.0L under its warranty coverage. Stated differently, I was aware of the upgrade to GF-5 spec from GF-4 spec for the C945A oil. But, it's my understanding that Jaguar still specifies certain oil properties that are inconsistent with the requirement of GF-5, properties which call for the C925A (GF-4) formulation for warranty coverage.
Old Jan 25, 2015 | 10:29 PM
  #49
Foosh's Avatar
BINGO!!! That is the crux of the issue. If JLR has decided to stick with an older spec for whatever reason, then for warranty reasons, it behooves one to stick with their recommendation.
Old Jan 26, 2015 | 04:47 AM
  #50
Unhingd's Avatar
Other than Castrol, you are going to be hunting for NOS oil, then. 945 exceeds the 925 specifications. Of the top brands, it appears that the Castrol Edge Syntec is one of the few that doesn't meet the 945 specs, but is adequate to meet the 925 specs. Redline, AMSOIL and Mobil 1 meet both.
Jaguar probably stuck to the old (lesser) spec because that was the best spec available when the engine was developed.
Old Jan 26, 2015 | 06:23 AM
  #51
Foosh's Avatar
More and more, manufacturers have marketing agreements with oil companies, which is the likely reason. Stickers are appearing in engine compartments (e.g. Mercedes recommends Mobil 1, Jaguar recommends Castrol, etc.)
While I cannot imagine that JLR would attempt to void someone's warranty for using a higher spec oil that meets or exceeds their recommendation, stranger things have happened. However, it's difficult to imagine that they could make that stick in court.
The bottom line is, the key to no-hassles warranty service is to have the dealer enter records for your car into the JLR system so that it is documented as having had all the recommended maintenance. For that, it's just easier to go to the dealer for annual service, at minimum.
It wouldn't surprise me if some JLR dealers are using oils other than Castrol, since they are independent businesses looking for the best deal.
Old Jan 26, 2015 | 03:47 PM
  #52
deltagroup's Avatar
Completely agree on each of your points. As time goes by, I find myself less and less surprised by just about anything that happens, heh. (BTW, take care back there. Looks like y'all back in the NE are in for some storm.)
Old Jan 26, 2015 | 04:28 PM
  #53
Foosh's Avatar
Thanks, we are essentially unscathed in the DC area. It's NYC north that is going to get killed.
Old Jan 26, 2015 | 05:20 PM
  #54
DJS's Avatar
DJS
Us, for example. Already snowing lightly here...
JagBrian
Aug 18, 2019 05:07 PM
ZJag
26
Sep 5, 2016 03:33 PM
bdboyle
Sep 4, 2015 06:16 AM
Jag-o-nomic
Sep 4, 2015 03:07 AM
pnwrs2000
Sep 3, 2015 11:55 AM
