First trip to a drag strip!
Old Aug 29, 2019 | 11:46 AM
Miauuu's Avatar
Originally Posted by casper83
If the track is reasonably prepped you shouldn't have to do anything with tire pressures since you're awd. Dynamic+S and let the computer do the work. Left foot brake, right foot throttle to the floor, release brake when the last amber comes on (before the green light goes on).
Wait, full throttle won't overpower the brakes?
Old Aug 29, 2019 | 12:37 PM
SinF's Avatar
It won't, but doing this isn't good for your AT so don't start doing it at every red light...
Old Aug 29, 2019 | 02:36 PM
Awd's Avatar
Awd
I have a vague recollection of a drag racing thread that specifically said don’t rev with the brake on as it will bog when you lift the brake. I’m assuming Casper 83 you have had success with the “brake on floor it “ method ?
thanks
Old Aug 29, 2019 | 03:20 PM
Unhingd's Avatar
The V6S has a launch mode that increases the stall speed of the torque converter. Involves applying the brake. I’m not familiar with the technique since I don’t have an AT.
Old Aug 29, 2019 | 04:45 PM
Miauuu's Avatar
Press the brake pedal and hold with the left
foot.
Select either Drive (D) or Sport (S).
Using the right foot, lightly press the
accelerator pedal until the Message centre
displays DYNAMIC LAUNCH READY.
5. Release the brake pedal, then quickly press
the accelerator pedal to the kickdown
position. The Message centre will display
DYNAMIC LAUNCH ACTIVE.
Note: Any manual gear selection, from the gear
selector or steering wheel gearshift paddles,
will override the Dynamic launch operation.
Dynamic launch will remain available for further
use after a short period of time.
Note: Dynamic launch will not be active when
the accelerator pedal is released from a high
demand position.
Prolonged application of the brake pedal will
deactivate Dynamic launch.
Note: Dynamic launch is not fitted to all
derivatives.
Old Aug 29, 2019 | 04:51 PM
Poison Ivy's Avatar
I believe my 2018 R also has a launch mode that involves holding the break and pressing the gas until a certain RPM. I read that somewhere and I thought it was in the manual. I’ll have to check.
Old Aug 29, 2019 | 05:33 PM
OzXFR's Avatar
Nup, no V8 F-Type has ever had launch mode it is and was only ever available on the V6S.
You need to be wary of what the Owner Manual / Handbook says as it is generic across all variants of that model year so it included everything that could possibly be on any model.
Old Aug 29, 2019 | 05:54 PM
  #28
scm's Avatar
scm
Bzzzt! It's available on the 4-pot, too.
Old Aug 29, 2019 | 06:12 PM
Poison Ivy's Avatar
Yep, it’s in the manual under DYNAMIC LAUNCH. It does state that “The dynamic launch system is dependent on the specification of the vehicle”. Not a very clear manual. Lesson learned.
Old Aug 29, 2019 | 06:18 PM
  #30
OzXFR's Avatar
You learn something new every day around here!
Old Aug 30, 2019 | 08:53 AM
  #31
Unhingd's Avatar
It's strange that it would be available on the I-4, but not the base V6.
Old Aug 30, 2019 | 08:58 AM
  #32
Unhingd's Avatar
+1. There's no need on the V8, as it has plenty of torque from idle to spin the tires. The V6, however, needs all the help it can get.
brit
Jul 19, 2019 07:12 PM
Geoffg1234
Nov 18, 2016 06:45 PM
Unhingd
US Northwest
Feb 16, 2016 03:04 PM
Unhingd
US Central
Dec 9, 2015 10:44 AM
tberg
Nov 22, 2014 05:14 PM
