Front Clearance / Start up Volume - V6S vs V8
Old Oct 7, 2019 | 12:41 AM
andrew0068's Avatar
Default Front Clearance / Start up Volume - V6S vs V8
I'm trying to decide between a V6S and V8 and two factors that may influence my decision are driveway clearance and start up volume:
- anyone know if a V6S has a little more clearance at the front than the V8 (due to weighing less)? The V8 I test drove barely had enough clearance to get out of my driveway: it scraped just a little. Not really any potential to drive out on more of an angle due to the narrow street and car park exit guttering/kerbs.
- the V6S seems to be less noisy on start up, although I wasn't able to do a side-by-side comparison. The communal parking area echoes like crazy and I don't want to totally annoy my neighbors.
Old Oct 7, 2019 | 05:53 AM
jaguny's Avatar
I backed my R into my steep entry angle drive and was able to ease it out going forward. The things we do......
Old Oct 7, 2019 | 06:53 AM
Chrissyg's Avatar
V6 is definitely less noisy than the V8, no doubt about that!
Old Oct 7, 2019 | 07:30 AM
scm's Avatar
scm
True, but the V6 is far from being a quiet car.
Old Oct 7, 2019 | 12:55 PM
Unhingd's Avatar
No difference in ride height between the two, but the AWD versions sit about an inch higher than the RWD.
Old Oct 7, 2019 | 02:09 PM
RickyJay52's Avatar
With the V6S you will only “partially” annoy your neighbors. Numerous threads have been written about “start-ups and neighbors” and the 18-month old boy next door to me is still crying based on Itsmejoshy’s starting up. And that was over a month ago! But then, that’s a totally different story. OH-OH...
Old Oct 7, 2019 | 02:45 PM
scm's Avatar
scm
Having a gorgeous car will annoy your neighbo(u)rs without needing to turn the engine on.
Old Oct 7, 2019 | 03:07 PM
Carbuff2's Avatar
The more times you scrape the little aero lip in front, the more clearance you create.
Remember, all three pieces of that lip cost less than $100 USD total.
Old Oct 7, 2019 | 03:21 PM
fuzzysquid's Avatar
Do we have a write-up for this anywhere? I'm assuming the parts to order are 20, 21, and 22 correct?:
Just wondering if there's any disassembly that needs to be done as the image suggests or is it a straight bolt on?
Needless to say my front spoiler pieces are getting pretty worn...
Old Oct 7, 2019 | 05:29 PM
devmen's Avatar
There's a plastic bit even under the 3 pieces of the lip that takes the majority of the scrapes. I felt better about that getting beat up while my lip pieces are untouched. I think Unhingd mentioned this plastic part is only 30 bucks.
Old Oct 7, 2019 | 05:53 PM
Unhingd's Avatar
No write-up needed. Just unscrew the visible bolts. Would be best to jack up the front of the car a bit to improve access.
Old Oct 7, 2019 | 06:07 PM
fuzzysquid's Avatar
Which part are you referring to? Is it on the diagram I posted?
Old Oct 7, 2019 | 06:20 PM
Unhingd's Avatar
20, 21 and 22 are the only bits I’ve ever scraped, and that’s with the 30mm lowering springs. I still haven’t installed my spare set after 32k miles. I just trim off the streamers occasionally.
Old Oct 7, 2019 | 07:25 PM
RacerX's Avatar
Banned
The legendary V8 "two footed start" is the perpetual crowd pleaser at Cars & Coffee. The crowd yells,"Again! Again!!"
The two footed start is left foot on the brake while your right foot holds the gas pedal on the floor, then press the start button. For some reason this results in an unbelievable amount of pops and crackles on the crescendo, and even more on the way down which seems to go on forever. An running engine rev only produces maybe 20% of the fireworks. You can also rev within about 3 seconds of engine start and get the same effect. Make sure the car is still warm so you're not hard reving a cold engine.
Yeah, I know there is probably some reason it isn't good for the cats or dogs. I figure I owe it to those who haven't fully lived their lives.
Old Oct 7, 2019 | 07:29 PM
lizzardo's Avatar
I made a little tool that cleans them up in a jiffy. The pieces make a lot of noise, as I'm sure they're intended to, but I've yet to hit anything more substantial than those feelers. I've learned the driveways that are an issue and take those slowly. Otherwise, I don't worry.
Old Oct 10, 2019 | 03:48 PM
David Meier's Avatar
I've said this before, no one ever said "I wish I had gotten the smaller engine". With that said, the start up noise is a bit startling for the uninitiated. My dogs still run when I get in to my V8S to head out. . It's not a car (either in the V6 or V8) in which you're going to sneak out of the lane unnoticed so get the model you like.
Luc Lapierre
Aug 29, 2019 07:27 PM
Barry Moore
Jan 31, 2017 06:08 AM
santacruzmg
Jan 27, 2016 07:55 PM
Jesse James
Aug 17, 2014 09:43 PM
AdzBo
20
May 18, 2012 11:43 AM
