Ftype not the same after new tires
Old Sep 21, 2019 | 07:26 PM
diablomkii's Avatar
Default Ftype not the same after new tires
Havent posted here in a while, but had nowhere else to turn to get a satisfactory explanation, so here goes...
All started when I noticed a nail in my rear driver tire. Took it to tire shop, ordered a pair of new pzeros and had them change both the driver and passenger rear tires.
Since then car started feeling unstable and mildly swerving at high speeds. Took it back to tire shop to check balancing and the rear passenger turns out to have a dent. So I take it to a wheel shop and they fix the dent and I'm happy because my baby will be as glued to the road as before, except it isn't.
It feels much better, but still not the same as before.
Car feels "slippery" at speeds above 60. Like driving in a windy day when the wind pushes you side to side. Steering also feels "looser". Not dangerously obvious, but noticeable to the point that I'm not enjoying driving it.
I miss my glued to the ground car that wouldn't even budge doing 120 on the same road where it now feels unstable at 75.
Please help.
Old Sep 21, 2019 | 08:28 PM
lizzardo's Avatar
A few things I'll throw out:
Tire pressures? Perhaps they're not the same PZeros? Maybe something wrong in the front? Maybe whatever dented the rim put the rear out of alignment?
Old Sep 21, 2019 | 08:38 PM
diablomkii's Avatar
Tire pressures are fine.
They're the exact same pzeros as the ones before...checked the number on them. They're also installed properly ie, inside/outside.
Can alignment go out on the rear axle?
Old Sep 21, 2019 | 09:03 PM
Unhingd's Avatar
Definitely. The rear toe can be adjusted.
Old Sep 21, 2019 | 10:48 PM
DJS's Avatar
DJS
How old are the fronts, I.e. how much tread is left?
Old Sep 22, 2019 | 01:05 AM
Nati's Avatar
Alignment
Old Sep 22, 2019 | 01:58 AM
Unhingd's Avatar
Originally Posted by Nati
Alignment
+1.
Old Sep 22, 2019 | 08:43 AM
Carbuff2's Avatar
When you say "the exact same pzeros as the ones before" are they marked JRS on the sidewall, meaning Jaguar-spec? There are several variations of PZero out there, each with different rubber compounds.
(Just look at the Tire Rack selection...10 different PZeros in our rear size!!!!!)
https://www.tirerack.com/tires/TireS...earDiameter=17
Unless you specified, I bet the tire store didn't worry and got whatever was 'in stock'.
For the record, our replacement rear PZeros are marked 'AMS' (Aston Martin? AMG-Merc?) and there is no funky handling.
My advice is to:
1. Verify proper cold air pressures F&R. (I've had tire store monkeys leave them at the same inflation as they needed to 'pop the bead'. )
2. If that is OK, see if increasing rear pressure a bit (no more than two PSI) calms the rear down.
Also, remember that tires often need a 500 mile Break-In before they grip fully. New tires have the little 'bumps', and mold release compounds on the tread.
I'll never forget the first time I bought new tires years ago, and on the way home, I took one curve at the same speed I was used to...and almost ended up in the ditch on the other side of the road! Thankfully there was no oncoming traffic!
Old Sep 22, 2019 | 10:10 AM
RacerX's Avatar
Banned
It's possible you have a defective new tire.
Old Sep 22, 2019 | 05:46 PM
jaguny's Avatar
When you mean the tire was "balanced" do you mean "road force balanced"?
Old Sep 23, 2019 | 07:10 AM
StormtrooperFtype's Avatar
Please help.
I just put PS4's on my car and experiencing the exact same thing! the car was just aligned as well, due to a recent mishap, all the wheels are in perfect shape, but the alignment shop said that they needed to put the passenger side camber at 0, instead of negative one, to get it on straight, due to damaged control arms, they are on order so hopefully its the control arm and lack of camber, and not the supposedly best tires for the F-type.
Old Sep 23, 2019 | 07:57 AM
SinF's Avatar
Random idea - tire shop damaged ride height sensor, symptoms match ones reported when one malfunctions.
Old Sep 23, 2019 | 12:50 PM
JagRag's Avatar
Havent posted here in a while...doing 120 on the same road where it now feels unstable at 75.
Please help.
Should you really be "doing 120 on the road"? Me-thinks the tire and speed god's have conspired against you!
Old Sep 23, 2019 | 04:03 PM
Unhingd's Avatar
Let's just say that the road was Roebling Road and return to the discussion of the real issue.
Old Sep 24, 2019 | 11:07 AM
People that share their opinions on people speeding, Drive how you like, don't tell others how to drive
Old Sep 24, 2019 | 11:19 AM
Carbuff2's Avatar
I'm sure that the "120" reading was on the km reading of the dial. You would be run over here in NJ if you went THAT SLOW on an Interstate.
(I always give folks the benefit of the doubt, you see)
Sick XF
Mar 29, 2016 03:08 PM
bookman
35
Dec 29, 2014 08:43 AM
MCW739
Aug 13, 2013 02:57 AM
ollison
Aug 13, 2012 03:29 PM
steevo124
Jul 10, 2009 10:44 AM
