Goodbye Meridian, helloooow Audison!!!
Old Aug 12, 2025 | 12:50 PM
  #81
TH3FRB's Avatar
Originally Posted by Robtrt8
No, I’m running my own crossover points and slopes. There is plenty of overlap in the available signal from the three door channels.
As long as you're happy with the results, but that's not the correct way to do it if you aren't summing the input channels first. You are layering additional x-overs and slopes on top of what's already there. Ultimately all that matters is you like how it sounds.
Old Aug 12, 2025 | 11:21 PM
  #82
JagCode3's Avatar
This is why a digital preamp like the DED or mObridge is the way. Applying crossovers on top of the Meridian amp's factory set crossovers, time alignment, and gain settings is a time-consuming journey down a frustrated rabbit's hole. Plus you can boost the digital signal up to 10 dB without distortion if you want.
The F-Type is not easy to tune either, even when on a battery maintainer. The head unit shuts down every 5 minutes and sometimes will not come back on for a few minutes. The BMS will do this to save the battery despite having the maintainer connected. Then there's the "battery low please start car" warning that comes on even when your battery is at 100% SOC!
Old Aug 13, 2025 | 07:35 AM
  #83
TH3FRB's Avatar
Ran into this last week and it's very frustrating. I was just about to post a thread asking if anyone has figured out a solution to keep the system powered up.
Old Aug 13, 2025 | 07:49 PM
  #84
JagCode3's Avatar
You can tune with the engine running (which I guess would be the most life-like), but I decided to do one speaker at a time then reboot. I worked quickly too.
Wear earplugs because pink noise at tuning level can really damage your hearing.
MvLXJR
Oct 24, 2023 02:06 PM
Spikepaga
Jan 8, 2019 11:56 AM
Spikepaga
Jul 15, 2017 06:59 PM
cdre
Jul 6, 2017 10:06 PM
WesSide
Audio/Visual Electronics
Jun 1, 2010 05:32 PM
