Heated windshield washers?
Old Nov 22, 2015 | 12:03 PM
DuhCar's Avatar
Default Heated windshield washers?
Do our cars heat the windshield washer fluid when spraying like some models of BMW?
Old Nov 22, 2015 | 12:25 PM
Foosh's Avatar
I don't know, but I doubt it. The reservoir filler is at the rear on the trunk, and I don't see where the heat source would come from. There are more options for doing that in the engine compartment.
At any rate, windshield washer fluid does have anti-freeze properties, so it will flow just fine in frigid temps.
Old Nov 22, 2015 | 01:43 PM
Mikey's Avatar
Not to mention that spraying hot fluid on a frozen glass surface is not a good idea.
Old Nov 22, 2015 | 01:55 PM
DuhCar's Avatar
BMW thinks it is.
1) it's probably not that hot, and
2) it's in the form of a spray so not a big thermal shock
Old Nov 22, 2015 | 02:20 PM
Mikey's Avatar
Then what purpose does heating the fluid have?
Old Nov 22, 2015 | 03:11 PM
F-typical's Avatar
On cars with more conventional washer jets (bonnet mounted), the heater element is in the Jets themselves, and is designed to prevent them from freezing up. The washer fluid will be at whatever temperature the area around the reservoir is, so probably not hot as such.
Does anyone remember the fun of pouring hot water on the washer jets to get them to thaw out? From memory, anything below freezing plus speeds of over 50 would cause it - even with neat screen wash...
Old Nov 22, 2015 | 03:17 PM
Cambo's Avatar
There is no heating in the wiper wash system on the F-Type, nor on any modern Jags that I can recall.
With the sprayer mounted on the wiper arm I think they are less susceptible to freezing up than bonnet mounted ones.
Old Nov 22, 2015 | 03:23 PM
DuhCar's Avatar
Ah, that makes sense. I just remembered on my previous BMW that something was heated. Thanks!
Old Nov 22, 2015 | 03:30 PM
Mikey's Avatar
Washer fluids here have a freezing point of -30C* or -40*C, so the jets freezing over would be unheard of.
Old Nov 22, 2015 | 03:44 PM
Foosh's Avatar
Yes, I think there are people who put water in the reservoir, or dilute the fluid w/ water, which I wouldn't. I never had any freeze in my 10 years in Minnesota with proper wiper fluid.
Old Nov 22, 2015 | 09:11 PM
DJS's Avatar
DJS
My Lincoln LS had heated wiper rests - a heating element in the windshield where the wipers rested. Kept ice from building up on them. I miss having that.
Old Nov 22, 2015 | 10:17 PM
JgaXkr's Avatar
The earlier Jags had that as well.
Old Nov 23, 2015 | 05:56 AM
Unhingd's Avatar
I'm certain the heated windshield will serve adequately to keep the washer fluid from freezing when the temps gets down to -50F.
Old Nov 23, 2015 | 01:21 PM
Mikey's Avatar
If it ever goes to -50F we'll all face bigger problems than frozen jets on our bonnets
Old Nov 23, 2015 | 09:49 PM
Unhingd's Avatar
Happens in Minnesota all the time (well, at least once every year or so). I remember having to drive my car several blocks in first gear because I couldn't move the gear shift lever.
mick99
Jan 14, 2016 07:32 PM
01Silverstone
Nov 24, 2015 02:05 PM
sasie007
Nov 24, 2015 07:15 AM
sklimii
US Lower Atlantic
Nov 21, 2015 03:32 PM
Jacob Greer
Nov 21, 2015 03:32 AM
