Help with fuses, please.
Old Nov 12, 2018 | 09:29 AM
FullChat's Avatar
Default Help with fuses, please.
I have a battery drain that appears to be caused by the Hazard Light "button" - it's lit 24 hours after I turn off the car. I'd like to pull the fuse for the Hazard Lights until I can get the drain fixed in a couple of weeks, but can't find which fuse to pull in the manual - nothing refers to what I think a Hazard Light button is. 2017 Base Coupe.
Can anyone help? Which fuse box, which fuse?
Old Nov 12, 2018 | 09:32 AM
DJS's Avatar
DJS
Typically, one disconnects the battery for a minute or two to fix the issue of the car not going to sleep. Discussed in many, many threads. The problem is usually initiated by connecting an OBD reader.
Old Nov 12, 2018 | 09:42 AM
FullChat's Avatar
Yes - it was read with an OBD reader and I disconnected the battery (twice!) - and the problem persists. Now I jut want to pull the fuse so my battery lives.
Old Nov 12, 2018 | 10:00 AM
DJS's Avatar
DJS
Not clear to me if that fuse would help (if you can locate it.) I suspect the battery is drained by more than the hazard light not going out - other things aren't going to sleep.
My manual doesn't list a fuse for the hazards either.
Old Nov 12, 2018 | 04:04 PM
stmcknig's Avatar
Agreed I think the "hazard light" is just a tell tale that the car is still wide awake....if you kill the fuse for the hazard circuit I suspect Medusa lives on....
Old Nov 12, 2018 | 07:09 PM
FullChat's Avatar
Well, maybe there are more circuits open, but if I can shut off the drain from this one - the one that I know about - it should result in less drain, don't ya think... I don't have a battery charger at the house, and am having to drive it every day (real first world problems ;-) just to charge the battery. The dealer can't give me a loaner for two more weeks...
Old Nov 12, 2018 | 08:24 PM
Unhingd's Avatar
Best to just disconnect the battery when the car is parked for an extended period until you get it to the dealer.
sinker123
40
Jun 25, 2018 01:22 PM
cbryantjr85
Oct 21, 2016 03:46 PM
Niatsahc
May 10, 2013 02:23 PM
JimC64
Nov 22, 2012 07:26 AM
driftr319
Jul 29, 2011 12:30 PM
