HELP! Info display going crazy
Old Dec 30, 2018 | 12:37 PM
CRS 123's Avatar
Default HELP! Info display going crazy
Started my Jag and got this on the touch screen display. Buttons on side seem to work but of course I can't see anything. Any way I can resolve this?
Old Dec 30, 2018 | 12:49 PM
malbec's Avatar
I guess the first thing to try is the battery disconnect remedy.
Old Dec 30, 2018 | 12:56 PM
CRS 123's Avatar
Could you walk me through that?...
Old Dec 30, 2018 | 01:10 PM
sov211's Avatar
Easy: disconnect the two leads from the main battery, touch the two ends of the leads together for a few seconds, reconnect. You will have to reset the window switches (this is in your owner's manual). But is your battery at full charge?
Old Dec 30, 2018 | 01:39 PM
CRS 123's Avatar
Thank you! Yes, battery at full charge. I let the car sit for awhile and double locked it....when I went back, the screen had returned to normal function. Being that this is the first time this has occurred in driving the car for a year and a half, it's possible that this is a symptom of things to come. I will keep your instructions on file for possible future occurrences:-) Thank you all for taking the time to help me out!! Happy Hollidays.
CRS
Old Dec 30, 2018 | 03:25 PM
vika01's Avatar
Seems like it's a classic graphics card issue seen on computer screens too.
Old Jan 1, 2019 | 03:43 AM
Tel's Avatar
Tel
Your car is still under warranty, so take it back and they should replce the unit.
If it were me, I would remove the head unit, and I bet it's the ribbon cable and very fine pitch connector that connects the PCB to the screen has a partial connection.
Just a wiggle first would most probably suffice, if not delve deeper.
Dealers will just chuck the old unit in the skip I guess...cheaper than fault finding these days!
Old Jan 1, 2019 | 10:58 AM
usgpru27's Avatar
I am curious as to the method of touching the leads together? May I ask why that is necessary? Honestly I have never heard of this before with a battery reset?
Old Jan 1, 2019 | 11:15 AM
Sean W's Avatar
Disconnecting the battery and touching the leads together discharges any current remaining in modules (capacitors) and in theory resets, the screen in this case. Jaguar recommends this on a few of their TSB's. If it doesn't work, no harm done. For those in Europe, you might want to save your radio code so you can re-enter it if needed. No code required here in the U.S.
Old Jan 1, 2019 | 01:52 PM
stmcknig's Avatar
With a lot of radios, unless it sees a VIN change, no code entry is required.
Old Jan 1, 2019 | 05:24 PM
usgpru27's Avatar
Thank you !! Will make it part of my SOP’s moving forward.
Magna1969
Mar 16, 2018 09:10 AM
draguarxkrsgt
Apr 27, 2017 03:55 PM
Spikepaga
Sep 8, 2015 08:06 PM
lozzer65
Apr 15, 2014 05:59 PM
User 070620
Jan 29, 2013 03:45 AM
