how to make the f-type stiffer
Old Feb 14, 2018 | 08:21 AM
indietor's Avatar
Default how to make the f-type stiffer
is the only no good point for me
stock is not stiffer on the supension like porsche
put lowering springs eibach can improve a little ?
i really jump on certan point where with the cayman i don't jump
Old Feb 14, 2018 | 08:52 AM
Stohlen's Avatar
Number 1 misconception about suspension: stiffer isn’t always better. I think if you try to stiffen up the F type you’ll just make it more uncomfortable and it will handle worse.
Never once have i felt this car needs a stiffer spring rate or less body roll, but people complain about that constantly. Dynamics of a vehicle are very complex, and a lot of engineering has gone into getting the suspension where it is.
Old Feb 14, 2018 | 09:04 AM
ek993's Avatar
+1 just look at what Lotus have accomplished in the suspension dept to realize that stiffer isn’t better
Old Feb 14, 2018 | 09:09 AM
indietor's Avatar
yes i agree with you guys
but i need to learn the different dynamic of that car ... because when is not bumpy it have great handling
Old Feb 14, 2018 | 09:30 AM
4x4uk's Avatar
if you are running in dynamic mode try setting suspension to std rather than dynamic see if that feels better on the road
Old Feb 14, 2018 | 10:02 AM
Stohlen's Avatar
Stiffer suspension is only going to make that problem worse. You need better dampening if you want to eliminate bumpy... that only comes in more complex suspension systems like magnetic ride or alike that aren’t offered for our car.
Old Feb 14, 2018 | 11:55 AM
zmoothg's Avatar
If anyone finds a great solution to the F-Types horrible suspension please let me know. The car does jump a lot more than even my friends 718 cayman or my old G35 coupe on coilovers. I used to love running Skyline Blvd in the Infiniti, the car was nice and planted; however, in the F-Type it's way too bouncy for the uneven terrain. The roll could also be slightly better, but it is not a show-stopper like the bounce.
Old Feb 14, 2018 | 12:52 PM
Chawumba's Avatar
4000lbs doesn't help...
Agree with others, lowering springs often improve looks more than handling.
Old Feb 14, 2018 | 12:57 PM
indietor's Avatar
same of me on cayman
i think the solution will be KW 3 coilover spring
Old Feb 14, 2018 | 01:02 PM
AnD3rew's Avatar
I find the F to be a reasonable compromise between too stiff and uncomfortable and too soft and rolly. As others have said what you are describing sounds like too stiff rather than not stiff enough, stiffer will make that problem worse.
If you have the dynamic suspension try configuring your dynamic mode with the standard suspension set up and see how that goes, it might improve your road feel on those sections.
Old Feb 14, 2018 | 01:35 PM
indietor's Avatar
the comfort is not my goal , i prefer more handling and no bumpy on the roads....sometimes it litterally FLY on the bumps like a leaper ahah
indietor's Avatar
cayman was a razor in the turn
Old Feb 14, 2018 | 03:06 PM
Stohlen's Avatar
See but you’re not listening... stiffer = more bumpy. Better damping will make it handle better, stiffer suspension will just make it more uncomfortable (bumpy) and handle worse.
Old Feb 14, 2018 | 03:10 PM
indietor's Avatar
sorry ,but
when i talk bumpy i don't mean when you hear all the bump on the road like porsche and lamborghini
jaguar is more comfortable on bumpy road and this is good if you go comfortable but if you want a more sporty drive is too much "comfort setup"
and stiffer i mean more sport setup
hope i explain what i mean because im not perfect with english
Old Feb 15, 2018 | 12:53 AM
AnD3rew's Avatar
sorry ,but
We understand you but I think you will find that while it will not handle like a Porsche you might improve its handling, not just its comfort by allowing it to damp a bit better on the rougher sections so use the softer setup on that section and see if it handles better, sporty better not just comfort better.
Old Feb 15, 2018 | 06:09 AM
indietor's Avatar
ok i give a try
Old Feb 15, 2018 | 07:18 PM
zmoothg's Avatar
Someone needs to get the KW 3 coilover springs and report back on the setup, too bad it doesn't interface with the cars electronic dampening control. The Porsche is the best balance of ride quality and handling, but then again Porsche is the king of suspension.
My car does almost literally fly on uneven payment extremely reducing now fast I can take these back mountain roads, lowered BRZs and Mini Coopers are kicking my *** on this road. My car needs better legs and a diet.
Old Feb 15, 2018 | 07:46 PM
Stuart@VelocityAP's Avatar
Check out our progressive rate lowering springs.
The drop is very moderate - 22mm - and due to the tapered coil you will NOT end up with a harsher/stiffer ride. However, upon loading they do increase in rate so body roll will be reduced, weight transfers quicker but not at the expense of damper function or ride quality.
Jaguar F-Type Progressive Rate Lowering Springs
__________________
Stuart Dickinson
Managing Director
VelocityAP Industries Ltd.
O: (1)250-485-5126
E: Stuart@VelocityAP.com
www.velocityap.com
Old Feb 15, 2018 | 07:59 PM
indietor's Avatar
hi stuart with the springs the "fly" go better ? a little improvement will be great , or only in weight transfers quicker , thx
Old Feb 15, 2018 | 08:24 PM
zmoothg's Avatar
I have the VAP springs, the fly is still there. I can't recall if its better or worse than stock in terms of reducing the car flying ability :P
