Incontrol Apps retrofit in MY2014
Old May 26, 2019 | 01:18 PM
antoine1911's Avatar
Default Incontrol Apps retrofit in MY2014
Hello,
I just finished retrofitting the Incontroll Apps in my F-type MY 2014.
It was not an easy job,
I did a lot of different retrofittings but this was the hardest one, I had to change the touchscreen to a newer model because it was not compatible with the Incontrol apps
But now after some months of investigation it works!
Johan from Belgium
Old May 27, 2019 | 08:31 PM
JgaXkr's Avatar
Please post more details & photos of the install. Do you have a breakdown of what parts need to be purchased? I am very interested in this upgrade as I am sure others are.
Old May 28, 2019 | 03:04 PM
Hi,
I get my information from different sources:
https://www.jaginfo.org/showthread.p...X250-starting-)
https://www.jaguarforums.com/forum/x...2013my-185785/
Freel2.com - View topic - InControl Apps Retrofit / Enable MY15 Freelander 2
Because off time difference and busy work I will give more explanation the next days.
Johan
Old May 29, 2019 | 01:46 AM
domino_z's Avatar
if you could retrofit the current 10" widescreen into f-type and sell as a kit....you'd be a millionaire
well not really, but you'd be able to upgrade to the extra large mchappy meal whenever your heart desired and not even feel it
Old May 30, 2019 | 05:45 AM
Hi,
Here are the parts that I have used:
Housing for TIM module YPC804470
IAM lead - TIM module T4N10311
FCDIM lead - TIM module T4N10312
USB - TIM module T4N10316
TIM Module DPLA-10F845-AF or DPLA-10F845-AG (Ebay)
USB port LR06579
eventually newer touchscreen
I have spend around 700 Euro for the hardware.
The retrofit is not easy plug and play, you have to dismantle a lot of parts and need acces to SDD for updating modules and change CCF
Because my touchscreen was not compatible I had to change it for a newer one (Ebay)
For the TIM module it should have the bracket for F-Type, the Landrover modules donīt have these and you cannot buy them separetely.
mrohrs16
XE ( X760 )
Oct 11, 2019 04:03 AM
thisissparta
Dec 18, 2015 06:39 AM
McGriddle
Aug 5, 2015 02:31 PM
XFactoR
Jul 20, 2015 11:26 AM
IronMike
Feb 16, 2015 02:48 PM
