the infamous carbon canister hose recall (K410)
Old Apr 26, 2017 | 10:25 PM
Frenchy's Avatar
Default the infamous carbon canister hose recall (K410)
With my annual service approaching, my dealership informed me that there are 3 active service campaigns that need to be performed. (Recalls, actually, but apparently they don’t recall recalls anymore; they just wait till the next service visit.) One of the three is “K410 carbon canister hose,” already discussed in another thread.
The dealership says this is a lengthly procedure that requires leaving the car overnight, getting a loaner. But someone on this forum posted a required time of “1.4 hours” for the procedure. If true, I’d like to show this to the dealership, since I’m not crazy about 2 5-hour round trips on consecutive days. So I’m appealing to your collective wisdom on this procedure. Can someone post the dealership’s technical info? It’s a sheet that explains, for each TSB or recall, the “situation, cause, action, parts, tools” etc., AND TIME, broken down to 10ths of an hour.
Old Apr 27, 2017 | 06:34 AM
Unhingd's Avatar
The service bulletin cites .9 hrs for the coupe and .6 hrs for the vert. Those times are conservative as JLR wants to pay as little as possible to the dealer for this warranty work. However, I have found that doubling the posted time for labor will get you very close to the actual time spent. See attached.
File Type: pdf
Old Apr 27, 2017 | 09:06 AM
Buckingham's Avatar
Mine took overnight. There is a great deal of interior panel removal to get at the canister. I think we would all like the mechanic to proceed slowly and carefully with this. Mine did and there were no visible signs of any damage.
Old Apr 27, 2017 | 11:04 AM
mwinner's Avatar
Let them take as much time as they need, they had my car for 2 days the first time and damaged it. I had to bring it back for 2 more days to replace the rear seat panel, and put the carpet back properly.
Make sure they have someone doing it who has done it before, and tell them to take their time.
Old Apr 28, 2017 | 09:32 AM
Awd's Avatar
Awd
Is the canister hose replacement limited to the V6 ?
Old Apr 28, 2017 | 09:37 AM
stmcknig's Avatar
I met the tech who did mine (he was working on the JustDrive update) and he said it wasn't too big a deal if you took your time. He had done several before so I just told them do it right not fast...
Old Apr 28, 2017 | 10:53 AM
Frenchy's Avatar
You can check the models and VIN ranges affected in the technical bulletin that unhingd helpfully attached to his reply (see his post above).
Old Apr 28, 2017 | 11:09 AM
DJS's Avatar
DJS
Thanks for pointing this out. Doesn't apply to my car, happily (North America MY15-17).
Old Apr 28, 2017 | 11:33 AM
myironlung's Avatar
infamous? never heard of it
Old Apr 28, 2017 | 11:50 AM
Awd's Avatar
Awd
Checked the vin...I'm within the sequence....but I noted the reference to V6....thus my question.
Any V8's which have had the replacement ?
Thanks.
Old Apr 28, 2017 | 08:04 PM
lizzardo's Avatar
I'm told that the evap issue to which my car is subject requires removal of much interior, including the seats.
Old Apr 29, 2017 | 04:42 PM
Nati's Avatar
this is correct...can't get any of the interior trim out without removing the seats
Old Apr 29, 2017 | 08:33 PM
lizzardo's Avatar
My initial thought was that the interior trim needing removal was in the cargo area, but when the technician mentioned seat removal, I modified that thinking.
Old Apr 29, 2017 | 08:59 PM
enfield's Avatar
I just had my car serviced and asked about this. Luckily my 2015 V8 S is not part of this. Bullet dodged
Old Apr 29, 2017 | 10:28 PM
Frenchy's Avatar
No question about it, K410 is an invasive procedure. Shoddy work could leave us with squeaks and scrapes. I know this has been discussed previously, but that thread has been dormant for a while, which is why I started this one.
Questions:
1. Does anyone have any recent experience with damage caused by K410?
2. Does anyone know just how necessary it really is?
3. Of course, the dealer will say that it has to be done. Has anyone refused?
Old Apr 30, 2017 | 07:23 AM
enfield's Avatar
Questions:
It's a service action and not a recall. I believe "K" donates that while a "J" is a recall.
Apparently, starting in 2016 Jaguar started putting in an S shaped piece. The hose is known to crack in the middle. That is what my service advisor told me. Since I had dodged the bullet; I did not ask any further questions.
I suspect it can be refused since it's not really a recall. I do not know the safety implications of the S-shaped hose cracking.
Old Apr 30, 2017 | 08:45 AM
Buckingham's Avatar
The hose will deteriorate sending gasoline fumes into the cabin and activating a CEL as the carbon canister is an emissions component.
Old Apr 30, 2017 | 02:53 PM
BigDuke's Avatar
MY16 Type R and looks like I'm in the clear as well thank goodness. Is it not specific to certain models and build dates?
