install instructions - guide - step by step for V8 upper & lower pulley change?
Old Mar 30, 2018 | 10:42 AM
sts-v's Avatar
Banned
Default install instructions - guide - step by step for V8 upper & lower pulley change?
Anyone have install instructions to do both upper and lower pulley installs, and what tools are required?
Old Mar 30, 2018 | 10:24 PM
Stohlen's Avatar
Searching is your friend.
Old Mar 31, 2018 | 08:15 AM
Itismejoshy's Avatar
Lower pulley - Stohlen did a solid write up:
https://www.jaguarforums.com/forum/f...pulley-179588/
Old Mar 31, 2018 | 11:14 AM
Timbo's Avatar
I wouldnt recommend doing both if i was you.
Old Apr 1, 2018 | 10:01 AM
sts-v's Avatar
Banned
And why is that?
Old Apr 1, 2018 | 10:21 AM
DJS's Avatar
DJS
I would think you'd hit the torque limit of the ECU/TCU even quicker with both pullies.
Caveat: I have no actual knowledge on the subject, just what I've read here. But I think that the torque limit can't/won't/shouldn't be modified by the tuners. You might ask Stuart at VAP for his opinion.
Old Apr 1, 2018 | 10:39 AM
RGPV6S's Avatar
Originally Posted by sts-v
And why is that?
If I recall correctly according to Unhinged and VAP using both pulleys overspeeds the supercharger at high rpm and its efficiency drops off so you don't really get all the extra boost you would expect at higher rpm. However I would imagine if you don't care about that it would move the torque curve into a lower rpm range which would probably be be good.
I also seem to recall that Unhinged has both pulleys but recommends not to use the upper one.
Old Apr 1, 2018 | 10:45 AM
DJS's Avatar
DJS
Remember that Lance has a V6, which uses a different supercharger, IIRC.
Old Apr 1, 2018 | 10:53 AM
RGPV6S's Avatar
You are right.
Old Apr 1, 2018 | 01:53 PM
Unhingd's Avatar
The TVS R1900 remains efficient into a higher rpm range than the R1320, so installing both pulleys on the V8 will indeed offer some advantage. The tuners do override the torque limiters which were put in place more to protect the poor performing weak link behind the steering wheel than to protect anything down through the drivetrain.
Old Apr 1, 2018 | 07:02 PM
sts-v's Avatar
Banned
Talking to VAP, they have previously tuned and recommend tuning for both pulleys. If stuart or chris said "dont do it," I wouldnt do it.
Old Apr 2, 2018 | 07:23 AM
Timbo's Avatar
Stuart said to me a while ago doing both overspeeds the charger, just saying what he said to me!!
princemarko
Jun 7, 2022 11:23 AM
o1xjr
Mar 19, 2014 05:32 AM
Nav
Nov 25, 2013 07:39 PM
SirJag
Apr 20, 2011 05:57 AM
brandon lip
Dec 16, 2010 03:36 PM
