Installation of Umbrella holder
Old Jun 18, 2021 | 09:33 AM
catfreak's Avatar
Default Installation of Umbrella holder
Just bought the original umbrella holder + umbrella for my F-Type Mj. 2020. The installation manual is quite poor. Anyone here who installed this device and has some experience to share?
Regards
catfreak
Old Jun 19, 2021 | 08:37 AM
Borbor's Avatar
Which bit are you unsure about ? Panel removal or attaching the brackets?
also do you have a coupe or convertible?
ultimately install is just drilling some holes through the appropriate panel and riveting the bracket through a washer on the back to give the rivet something to splay out against. Also you can just eyeball the width and distance from the edge of the panel if you can’t be bothered using the template guide and it will still be perfect.
Old Jun 19, 2021 | 10:04 AM
catfreak's Avatar
Hi Borbor,
thank you very much for your reply! After I´ve checked the available space in the trunk (it is a Convertible ), I decided that I´ll not install the holders.They just need to much space in the small trunk.
Kind regards
catfreak
Old Jun 19, 2021 | 10:22 AM
santacruz11's Avatar
gere i don't drive these cars in the rain !!!
Old Jun 19, 2021 | 08:27 PM
Borbor's Avatar
Originally Posted by catfreak
Hi Borbor,
Kind regards
catfreak
You can also choose a different installation location rather than the front lip so won’t impact on the load opening so much. Eg deeper in on the roof of the boot panel. You won’t see it on opening the boot and you will have to reach in deeper but still completely functional.
Old Jun 20, 2021 | 09:27 AM
catfreak's Avatar
Thank you for your suggestion! I´ll evaluate this but I´m already quite sure that I´ll not install the holders.
Kind regards
catfreak
Old Jun 20, 2021 | 06:51 PM
Unhingd's Avatar
I keep the umbrella in the trunk but also opted not to install the mounting straps. Randomly drilling holes through the sheet metal, and god knows what behind the panel, seemed ill-advised.
Old Jun 21, 2021 | 08:00 AM
Borbor's Avatar
agree random drilling is crazy but formal instructions actually require removal of the panel from the car to access the back of the panel. Panel is just compressed /glued carpet like material so actually easy to drill through and any drill holes are actually invisible later if you change your mind. I actually cut some slots through the side panel in my boot and added elastic straps to hold first aid kit and the tyre inflator as had no room in the underfloor area and it looks exactly like the oem elastic straps in the boot already . You could add anything really such as extinguisher holder , extra tie down spots easily if needed and yes it does require removal of the relevant panel. Or there are plenty of Velcro attached nets now too.
Old Jun 21, 2021 | 01:57 PM
Suaro's Avatar
I just put the collapsible umbrella in the elastic straps on the left hand side. I thought that was the umbrella holder.
Old Jun 25, 2021 | 10:59 PM
Unhingd's Avatar
the elastic straps at the front of the coupe boot are for storing the warning triangle required in some jurisdictions.
Old Jun 26, 2021 | 07:49 AM
Suaro's Avatar
Un, I learned something new. I took European delivery of a vehicle once and it came with warning triangles. I thought they were a good idea. Automobile regulations in the USA seem to be behind the curve on a regular basis.
Old Jun 26, 2021 | 08:33 AM
Dwight Frye's Avatar
I wondered what the two elastic straps at the forward edge of the trunk floor were for and the additional one on the left hand side. I bought one of those cargo nets for about $20 that can be attached to the two hooks on either side of the trunk area to carry loose objects if needed and keep a pair of bungee cords in the storage area under the floor. For an emergency kit, I bought a .30 caliber plastic ammo can from Harbor Freight and a couple of these emergency flashers to put inside along with a small spray bottle of quick detailer and another one with some glass cleaner plus a microfiber towel and a multi tool. The ammo can sits perfectly inside the storage hole and still allows the cover to fit on top. I'll probably add a small tool kit that will fit in the storage space as well.
Old Jun 26, 2021 | 02:15 PM
Unhingd's Avatar
SVR 575
May 20, 2021 02:45 PM
wcl4
May 7, 2021 06:06 AM
eeeeek
Feb 16, 2020 12:28 PM
jbajor
Feb 16, 2017 08:31 AM
maverick1
Nov 26, 2014 07:11 PM
