Jaguar ftype convertible 2014 during storms / windy weather drivers side floor wet
Old Dec 19, 2024 | 01:24 PM
aden25jones's Avatar
Default Jaguar ftype convertible 2014 during storms / windy weather drivers side floor wet
Hi guys,
During windy / stormy / rainy weather my jaguar ftype v6s 2014 convertible is getting wet on the drivers side carpet. I am having to dehumidify and use dehumidifier bags and kitchen roll to soak up water.
What could be causing this? I have ordered a high spec car cover but do you guys know from experience where the water is getting in? Also, car is not garaged obviously.
Aden
Old Dec 19, 2024 | 03:06 PM
DJS's Avatar
DJS
I’ll assume the roof was up.
On previous cars (decades ago), water in the passenger footwell was from an improperly installed windshield. I don’t think there’s a drain in the A-pillar.
Old Dec 20, 2024 | 10:05 AM
Carbuff2's Avatar
Another possibility, is the leaky-side window going fully UP? <----- would need to see if there is an adjustable stop on the shop manual of the PINNED "How To" topic) Also, verify that the window motor goes higher after the door is closed.
Compare both sides.
Give the top's header a yank where it meets the windshield header. Both sides should be 'tight'. <----- This is a lesson learned on a 1991 Mercury Capri 'vert--- an over tight latch would allow leakage on the opposite side.
Treating the symptom, not the actual problem: Do you treat the fabric on your top with ScotchGuard-type dressing as recommended in the Owner's Manual? That will allow the water to 'roll off' rather than be 'soaked in'.
A bit of silicone on the door opening's seals will resist water, too.
kb58
Aug 6, 2022 07:02 PM
NeverEnough
Jan 17, 2022 07:26 AM
99Gsp
US Northeast
Oct 3, 2015 06:19 PM
enderle
Jun 28, 2015 06:05 PM
shift
Dec 23, 2014 04:12 PM
