Jaguar track recommendations for the F-type
Old Jun 29, 2016 | 01:04 PM
DJS's Avatar
DJS
Default Jaguar track recommendations for the F-type
I just stumbled upon this document. Neat!
http://www.jaguar.com/Images/F-TYPE%...m76-110851.pdf
Old Jun 29, 2016 | 02:20 PM
Adz3000's Avatar
Thanks for sharing! Not seen that before.
Not sure if i'll ever see myself doing a track day in mine. We shall see.
Old Jun 29, 2016 | 04:23 PM
DJS's Avatar
DJS
I recommend it. I've done it twice, and had a great time.
Old Jun 30, 2016 | 01:30 AM
mp51998's Avatar
Anybody seen or used these brake ducts they are recommending?
Old Jun 30, 2016 | 08:28 AM
DJS's Avatar
DJS
That's the first time I've ever seen them mentioned anywhere.
Old Jun 30, 2016 | 11:46 AM
wjk_glynn's Avatar
I'm a bit surprised they recommend those brake ducts if you have the carbon ceramic brakes, but no mention if you have the steelies...
Old Jun 30, 2016 | 02:34 PM
mp51998's Avatar
I was surprised too. I figured these were the best for dissipating heat.
Old Jun 30, 2016 | 06:14 PM
sybarite's Avatar
Bizarre indeed. CCMs are capable of dealing with much higher temperatures than cast iron brakes (they are NOT steel BTW!).
Interesting that they warn of caliper discolouration, again only with CCMs. IME it is quite easy to achieve temperatures also with cast iron brakes that will discolour the calipers.
Also odd that they advise to remove the cooling ducts for street driving, apparently over concerns of debris, not temperatures. What sort of debris are they worried about that would interfere with brake operation and would not be able to get into the brakes without the ducts? Gravel/stones getting jammed up comes to mind as a typical debris problem, much more likely to get thrown up by a tire than enter through a duct, I would think.
Old Jul 1, 2016 | 01:01 AM
mp51998's Avatar
I have a request in with my dealer for a price, availability and pics. When i get it I will update.
Old Jul 1, 2016 | 01:04 AM
Arne's Avatar
Maybe they are conserned that the cooling ducts will scoop up rain/water and spray it directly on the discs, reducing the initial brakeing power?
Old Jul 1, 2016 | 02:15 AM
wjk_glynn's Avatar
The article says ...and if you have CCM with the brake ducts fitted, remove the ducts at the earliest opportunity in order to prevent road debris interfering with the braking components.
If your CCMs get chipped (with say stones), I think you have to bin them.
Karl.
Old Oct 7, 2016 | 03:35 PM
MaximA's Avatar
I've been looking for this PDF as it contains the part number, and now Jaguar as removed the page
Old Oct 7, 2016 | 03:48 PM
DJS's Avatar
DJS
Which is why I grab any document of interest as soon as I see it.
https://www.dropbox.com/s/bwcg2spgeb...10851.pdf?dl=0
Is this what you're looking for?
If your F-TYPE is fitted with the Jaguar Carbon Ceramic Braking
system (CCM), the fitment of brake ducts is recommended (part nos. T2R-15213 and T2R-15214). These should be fitted for track use only (they are not advised for road use) and are
straightforward to fit and remove. They assist with brake cooling on the track and are available from authorised Jaguar dealers.
Old Oct 7, 2016 | 04:00 PM
MaximA's Avatar
You are are man! Thank you, I thought I saved it!
Old Oct 7, 2016 | 04:02 PM
MaximA's Avatar
wholly crap they are over 6k per car!
Old Oct 9, 2016 | 03:41 AM
mp51998's Avatar
My dealer said they were discontinued.
No price given though.
Old Oct 9, 2016 | 03:32 PM
Mpowerr's Avatar
Does anyone one have a picture of these? I've been searching with no luck. Want to see where they go...
Old Oct 13, 2016 | 12:57 PM
Uncle Fishbits's Avatar
I wonder if they got rid of it because lawyers assumed it heaped a ton of liability on them?
