John Hennessey mods a 2017 Jag R series
Old May 25, 2017 | 06:49 PM
Ubad2's Avatar
Banned
Default John Hennessey mods a 2017 Jag R series
John Hennessey reviews the modified Jaguar.
http://youtu.be/u7GTeeWCgkM
Power:
• 616 bhp @ 6,500 rpm *
• 597 lb-ft torque @ 4,200 rpm *
Performance:
• 0-60 mph: 3.2 sec.
• 1/4 mile: 11.4 sec. @ 124 mph
Includes:
• Custom Software Upgrade Tuning
• High Flow Air Filter
• Supercharger Pulley Upgrade
• Professional Installation
• Dyno Tuning & Road Testing
• Serial-Numbered Dash Plaque
• Serial-Numbered Engine Plaque
• Hennessey Exterior Badging
• 3 Year / 36,000 Mile Limited Warranty
* Estimated power ratings at the engine. Actual power will be measured at the rear wheels, before and after the upgrades are installed and tuned. Rear wheel horsepower and torque figures are approximately 15-20% lower than the factory published power figures which are measured at the crankshaft on an engine dyno.
Old May 25, 2017 | 09:06 PM
Stohlen's Avatar
Hennessey has a history of bad business and is not to be trusted.
Old May 25, 2017 | 10:19 PM
Nati's Avatar
Couldn't you take an R from the dealer's lot to the drag strip and make nearly the same 1/4 mile?
Old May 25, 2017 | 10:29 PM
domino_z's Avatar
stock awd R will run high 11's, iirc best ive seen a mag run is an 11.7
there's also a solid 2-3 mph in that kit too
has anyone here ran up their vap or eurotuned car to compare?
Old May 26, 2017 | 06:00 AM
Unhingd's Avatar
When I checked a couple years ago, they wanted $13k for that package. Of that, I estimated they are charging $10k of that for the plaques, logo and warranty. This is just one example of what's been written about Hennessey: http://www.google.com/url?sa=t&rct=j...KoV8vUFlQNSFQQ
Old May 26, 2017 | 06:01 AM
Stohlen's Avatar
See signature. There's more left in it on the tuned run; the car was dumping fuel on the top end to cool the cats down. I'm hoping for an 11.2 on a perfect day.
Old May 26, 2017 | 08:01 AM
Mueller's Avatar
Time to remove the cats?
Old May 26, 2017 | 08:15 AM
Stohlen's Avatar
Probably would just be easier to move the temp probe. We're trying to address this problem with one step colder spark plugs, which I've already installed. However the other issue I'm having is I keep blowing the tires off the thing. The stock Pirellis start to slip at the top of 1st and 2nd and ESC cuts power on 50% of my runs. Upgraded tires are in order.
Old May 26, 2017 | 08:47 AM
Mueller's Avatar
Fair enough re the temp prob. With the M156 motor in the AMGs, people modding would remove the cats (good god they would get loud) and use software to prevent codes. The cats were rather restrictive on those cars. More than half, id guess, would take out the secondary cats (because there was no O2 sensor behind them, and thus no need to do software). I figured it would be a simple fix to the overheating problems in the X152.
Re tires, I can't seem to burn through the ones on my car fast enough. I look forward to slapping some good rubber on this car. I can't go full throttle in second gear at all right now.
Old May 26, 2017 | 12:10 PM
Mpowerr's Avatar
I've got the vap cats and it's extremely loud once the valves open. Regarding moving "the probe" there is no egt sensor or temp probe to move... I think it uses the oxygen sensor data to interpolate temp values.
Old May 26, 2017 | 01:48 PM
myer's Avatar
What tires would you fit?
Old May 26, 2017 | 01:56 PM
Stohlen's Avatar
Yes they are one in the same. But I believe this sensor is not for engine fueling purposes. More of a monitor of emissions and temp.
Michelin PS4S would be the likely choice. Going to a cup tire probably would be unnecessary.
Old May 26, 2017 | 02:40 PM
DPelletier's Avatar
pretty close, yep. http://www.motortrend.com/cars/jagua...t-test-review/
Dave
Old May 26, 2017 | 04:31 PM
Burt Gummer's Avatar
Well it is nice to hear someone who has driven just about everything have such high praise of the F-type.
Old May 27, 2017 | 06:07 AM
Ubad2's Avatar
Banned
Default Mr Scam man ....
Wow... this guy has a funked up business reputation ! Yet, he still posts new a video showing the 2017 Jaguar. Snake oil salesman.
Old May 27, 2017 | 08:48 AM
Stohlen's Avatar
People still buy his products. Enough people know the name from what he's done and ignore or overlook the risk associated.
Old May 27, 2017 | 09:21 AM
lsbrodsky's Avatar
When I was a Corvette Forum participant, his travails were well documented. Most people stayed away, but some were captivated by the grunt he added. I went to Lingenfelter and was very happy. I think there is always a better alternative.
Larry
Old May 27, 2017 | 09:43 AM
Stohlen's Avatar
Larry
Agreed. And Lingenfelter is a great community advocate here in Michigan. More than just another shop.
