Jump starting?
Old Jun 7, 2016 | 09:03 PM
Unhingd's Avatar
Originally Posted by uncheel
On a related note.. Graham has included a link to the Owner's Manual in the 'How To' Guides thread. You might want to download a copy for easy reference:
http://www.mediafire.com/view/d0vr8q...i6b/US_101.pdf
I believe it just has the 2014 US and UK versions, but you can get other years at JagDocs for under $5:
http://www.jagdocs.com/index.php?mai...&cPath=142_154
All the model years are available if you type in a corresponding VIN.
Old Jun 8, 2016 | 05:10 AM
AnD3rew's Avatar
Good to know about the emergency release, I hadn't picked that up, I thought it was just for the brake as that is the case for my Land Rover.
Yes connecting a jump starter to the underhood connections will give you enough power to open the boot/trunk. I have a portable jump starter but the car drained it dead without starting the car. I had to connect another car by jumper leads directly to the battery in the boot and leave it connected for quite a while before I could build up enough charge to start the car.
Old Jun 8, 2016 | 06:41 AM
SinF's Avatar
Word of caution - jumping a car with completely dead battery from a cheap portable starter can fry electronics. I strongly recommend boosting from another running car that has operational battery and a running alternator with a working voltage regulator.
Old Jun 8, 2016 | 09:50 AM
Unhingd's Avatar
+1.
Old Jun 8, 2016 | 10:29 AM
Foosh's Avatar
If you're stranded somewhere, with no jumper cables, or not in a position to hook-up to another running vehicle, you can do it safely by disconnecting the battery cables, and then hooking up your starter. That should quickly put enough charge into the battery to get going, unless the battery is defective and won't accept any charge.
Old Jun 8, 2016 | 11:16 AM
Unhingd's Avatar
Originally Posted by Foosh
+1
underscore: hooking up your starter to the BATTERY.
Old Jun 8, 2016 | 11:44 AM
Foosh's Avatar
LOL . . . what the heck else would you hook it up to? :-)
Old Jun 8, 2016 | 01:55 PM
  #28
Unhingd's Avatar
Straight to the battery cables...with disastrous effect. I've seen people do it.
Old Jun 8, 2016 | 01:57 PM
Foosh's Avatar
Well now that wouldn't charge a dead battery now would it?
Old Jun 8, 2016 | 02:13 PM
  #30
Unhingd's Avatar
Read your first sentence. Some folks aren't as conscientious as you are and don't read the entirety of the instructions.
Old Jun 8, 2016 | 02:18 PM
  #31
Foosh's Avatar
I figured they would read the 2nd sentence which says, "that should quickly put enough charge into the battery to get going." :-)
You know I love a good debate . . . LOL.
Old Jun 8, 2016 | 02:24 PM
  #32
DJS's Avatar
DJS
Don't Vettes use flint and steel rather than batteries to start?
Old Jun 8, 2016 | 02:54 PM
  #33
plums's Avatar
I actually had to re-read the passage and I'm not unfamiliar
with boosting vehicles.
As for the starter packs, I wonder if they output voltage in
excess of 15 volts. If not, then I cannot see how hooking it
up in the usual manner parallel to the circuit could result
in any over voltage. Perhaps the risk is in in-rush current,
but circuits only draw as much as they need and no more.
Old Jun 8, 2016 | 03:09 PM
  #34
Foosh's Avatar
Yes, I'm with you, but some manufacturers provide instructions in the owner's manual recommending charging dead batteries disconnected from the car. I remember seeing in a manual for a 2010 Mustang GT.
It's probably not a problem in the vast majority of cases just to slap on the jumper cables and crank, but it's also not a big deal to disconnect a battery cable before hooking up the jumper cables to the battery as an added precaution.
Old Jun 8, 2016 | 03:37 PM
  #35
DJS's Avatar
DJS
A disclaimer: the manual discourages hooking anything up straight to the battery, since the battery gives off hydrogen, etc. as it charges, which could be ignited when you disconnect the cables.
Most people know this, of course, but if you don't know what you're doing.... don't try it. And, good ventilation is your friend.
Old Jun 8, 2016 | 03:54 PM
  #36
Unhingd's Avatar
Unfortunately, it doesn't count when we are violently agreeing. lol
Old Jun 8, 2016 | 05:06 PM
  #37
Foosh's Avatar
Sure it does . . . it's even more fun. :-)
Old Jun 8, 2016 | 06:49 PM
  #38
Unhingd's Avatar
lol
ImNotFamousAnymore
Feb 12, 2026 06:38 AM
DJS
May 23, 2017 04:37 PM
o1xjr
May 27, 2016 09:29 AM
Ggraddy
Apr 16, 2016 11:31 AM
kingtutt
Apr 15, 2016 09:10 AM
