Klunking sound from rear when turning
Old Nov 7, 2024 | 02:41 AM
cookturkey's Avatar
Lightbulb Klunking sound from rear when turning
Hey everyone!
My F-Type V6S (2016) has developed a fault where it makes a deep clunking sound from the rear whenever I turn (video attached although very difficult to capture on camera).
This is present 99% of the time but every couple of weeks it completely disappears for a day (usually after a long drive on the motorway).
Rear diff oil has already been changed and didn't seem to make a difference. This is now driving me mad and was wondering if anyone had any idea what it could be?
Thanks in advance!
File Type: avi
Old Nov 7, 2024 | 06:23 PM
cpq100's Avatar
I watched the clip several times on two different computers with the volume cranked all the way up. It plays fine, but I can't hear any audio.
Old Nov 8, 2024 | 01:42 AM
cookturkey's Avatar
Sorry about this - bad video format. I have attached a new MPG video, thanks!
File Type: mpg
Old Nov 9, 2024 | 07:59 AM
cpq100's Avatar
The audio can now be heard, but the video is now gone. I can't really determine anything from what I hear. SWAGs at causes for noises in the rear would be suspension, lift gate, diff, or something rolling around in the trunk or the storage cubies in the trunk area.
Old Nov 9, 2024 | 03:30 PM
Michael211's Avatar
I had similar clunks while turning when my mechanic put something other than the Jag spec fluid in the diff. They went away when he refilled with the spec stuff.
Old Nov 10, 2024 | 07:07 AM
BenFT's Avatar
I had the same problem and same type vehicle. At the time it was still under warranty. It was coming from the rear differential. The dealership did a flush and refill with an additive and the problem resolved.
Old Nov 10, 2024 | 08:20 AM
Bschur631's Avatar
Does it only happen on a low speed turn with slight throttle input? Is you F-Type AWD? If yes to either, You need to perform a double flush of both rear diff and transfer box.
Proper way to perform procedure is to drive vehicle to get both units to "operating temperature" including doing figure 8's. Drain fluids and refill using recommended fluids. Road test again with lot's of figure 8's, drain and refill again, then another road test. Noise will be gone if being caused by diff or t-box.
Old Nov 15, 2024 | 09:50 AM
shawmanz32na's Avatar
As fate would have it, I've been experiencing very similar noises in my '20 R-Dynamic Auto. My "groans" aren't as loud as yours, though, and typically happen when turning at slow speeds when off throttle or with very light throttle input.
I brought the car in to the dealership earlier this week for end-of-warranty service and inspection and noted the noise. They "pulled a fluid sample" and have decreed that the car needs a new rear diff, which they're going to cover under warranty. I'm still prying for details about what they actually found in the sample and what they think the "failure" actually is, primarily as a means to prevent it from happening again.
Were this not covered under warranty, you can bet your breeches I'd be doing flushes and fills like has been recommended above before considering swapping out the unit.
Lavitz
Oct 9, 2024 11:47 AM
Dell Gailey
Oct 6, 2023 06:57 PM
iownme
May 10, 2021 07:29 PM
mykiaveli
Nov 11, 2018 01:38 AM
superflysocal
Apr 24, 2012 03:55 PM
