KW Height Adjustable Springs
Old Dec 2, 2020 | 07:27 PM
TM1238's Avatar
Default KW Height Adjustable Springs
I want to lower my car and corner balance it. The KW HAS (https://www.kwsuspensions.com/kw-sus...-25331005.html) look perfect. The only problem is that it states these will fit 2017+ only. The other HAS set that KW makes is for 2WD models only and my 2016 R is AWD. Has anyone tried fitting these to a 2016? If so how do you like them?8.5.5
Old Dec 2, 2020 | 09:46 PM
jaguny's Avatar
https://www.jaguarforums.com/forum/f...wheels-174687/
Old Dec 2, 2020 | 10:19 PM
TM1238's Avatar
I saw that one and a 2016 SVR, I thought thelink you sent was a 2015 but looks like it is a 2016. Thanks!
Old Dec 3, 2020 | 05:46 PM
jaguny's Avatar
I am pretty sure the KW HAS is made for '16 awd R as I recall looking into it. Do a search as at least one other forum member had them on their car. You can also contact KW directly to confirm.
Old Dec 12, 2020 | 06:47 AM
Unhingd's Avatar
Folks seem to have a lot of problems with the resulting ride heights on KWs.
Old Dec 14, 2020 | 06:13 PM
TM1238's Avatar
Can you elaborate on this? Too high, cant get low enough? They seem to settle in between the VAP springs and the Eibachs and H&R's in lowering height.
Old Dec 15, 2020 | 01:30 AM
Biofreak's Avatar
I have a KW HAS installed on my MY17 SVR. It settled quite a bit lower than where it was set at the time of install. So much so that I am scraping underbody and front plastics when going over speed bumps.
The nice thing is that you can adjust it higher (Which I will be doing next week)
Pic of the car at a Matric dance where I lent the car to a youngster (Yes, I need spacers....)
Old Dec 15, 2020 | 05:54 AM
TM1238's Avatar
Wow, yeah that got very low. Did you place them on the lowest setting to start? Before it settled out did you have a chance to evaluate the ride? I'm concerned with them being too soft.
Old Dec 15, 2020 | 06:42 AM
Biofreak's Avatar
It can still go lower
I had a 2014 F-Type R RWD which I also lowered with an H&R set. This is much stiffer. Almost too stiff if I'm honest. It's changed the traction dynamic from a standing start on slick roads - Not quite the right word, but it's introduced a torque steer feel from a hard launch. Feels like the rear doesn't compress as much on hard acceleration which feels like better get up and go. I've only measured with my butt dyno so who knows.
Cornering the car feels less neutral when you chuck it into a corner. With the stock setup I had a tendency to understeer when going in hot and oversteer when too slow. Now it just feels like the car won't rotate at all. Will see when I track it again in the new year to see if it translates into the same feeling on the limit.
Old Dec 15, 2020 | 08:37 AM
J444G's Avatar
yeah that seems like too stiff setup with not enough loads on tires. Also the geometry is probably affected if you are this low.
Old Dec 15, 2020 | 09:30 AM
TM1238's Avatar
So when you're saying it won't "rotate" do you mean les body roll or poor turn in on the corner? Overall it sounds like you think the handling performance got worse?
Old Jan 13, 2021 | 07:46 AM
Biofreak's Avatar
I'm describing it poorly...
The handling feels much better. Grippier. With the stock setup I had exaggerated oversteer and understeer depending how fast I went into a corner. With the new setup, it's much more neutral at 8/10's.
I did have the suspension lifted up a bit and the torque steer feeling is gone now. Squat and go from the line
Old Jan 13, 2021 | 08:12 AM
TM1238's Avatar
That height looks great! Like you said previously, some spacers on the wheels would look fantastic. Do you have any side profile pictures you could post?
Old Jan 17, 2021 | 09:58 AM
Biofreak's Avatar
Spacers added and the rear has been raised a hair:
Happy with it now!
Pax
Jun 4, 2019 01:56 PM
JVIII
Apr 13, 2018 06:35 PM
shahuk
Nov 1, 2017 11:19 PM
schwartzki
XE ( X760 )
Oct 20, 2017 06:20 PM
