Looking for member who asked about inventory on the Pierburg CWA150 Coolant Pump.
Old Feb 9, 2026 | 11:30 AM
scott@VelocityAP's Avatar
Sponsor
Default Looking for member who asked about inventory on the Pierburg CWA150 Coolant Pump.
We had a few forum members ask about inventory of the Pierburg CWA150 coolant pumps, as they are normally out of stock and hard to find. We did receive in a shipment of these and filled our remaining back orders, with a few left available (as of Feb 9, 2026) for anyone who was still looking for these. Here is a link to the product that also comes with a custom made wiring harness: Pierburg CWA150 Water Pump - 2010 MY-on Jaguar/Land Rover AJ133/AJ126 3.0 5.0 Supercharged Engines - Velocity Automotive Performance
__________________
Scott Rudowitz
Business Development Manager
VelocityAP Industries Ltd.
O: (1)250-485-5126
E: scott@velocityap.com
www.velocityap.com
Old Feb 20, 2026 | 10:25 AM
Adam Deermann's Avatar
Is the CWA150 a direct replacement? Is it acting the same way as the original pump?
What I understand is that the pump is controlled by the ECU.
wahat is the difference between the the pre 2015 setup “wiring modification requered”
thank you,
Adam
Old Feb 20, 2026 | 10:32 AM
Sponsor
thank you,
Adam
Adam,
It is a higher flow pump otherwise it acts and works like the OEM pump would function. We provide a wiring harness for the later model years, however earlier model years will require you to splice the wires to the pump or purchase a wiring harness you can modify to work.
__________________
Scott Rudowitz
O: (1)250-485-5126
www.velocityap.com
Old Feb 21, 2026 | 03:31 PM
bobjagbob's Avatar
Hi Scott,
Thanks for the update. The VAP website is a bit vague on how "direct" of a direct replacement it is.
VAP Website:
"PLEASE NOTE:
  • PUMP DOES NOT FIT CLEANLY INTO OEM SPACE, SOME MODIFICATIONS ARE REQUIRED.
  • NO BRACKET INCLUDED TO FASTEN, ZIP TIES OR OTHER FABRICATED BRACKET MAY BE NECESSARY
  • PROFESSIONAL OR DEALER INSTALLATION RECOMMENDED"
Do you all have any pictures, an installation video, or more information what this means.
Thanks.
Old Feb 22, 2026 | 03:11 AM
Sorry for all my questions, but I like to understand.
Will the pump run constant? The original pump is ECU controlled, is the CWA150 also ECU controlled. A fuse upgrade I assume?
Cooler intake air seems like a good thing to do, but is it the thing to do on a street car? Are there benefits?
Regards, Adam
Old Feb 22, 2026 | 05:45 AM
JgaXkr's Avatar
You will need to upgrade the fuse to a 20 amp otherwise it is plug & play. It will operate just as the original just a larger flow rate.
Old Feb 22, 2026 | 02:04 PM
Sponsor
Originally Posted by bobjagbob
Hi Scott,
VAP Website:
"PLEASE NOTE:
Thanks.
Here is a good video one of our dealers produced:
__________________
Scott Rudowitz
O: (1)250-485-5126
www.velocityap.com
Old Feb 23, 2026 | 02:43 PM
ER9240's Avatar
How does this pump compare to the Bosch 0392022002? I did some searching without success (admittedly, my searching skills aren’t the best). I have a brand new Bosch with correct wiring plug sitting on my workbench, but don’t want to waste my time if it isn’t any good.
Old Feb 24, 2026 | 07:09 AM
Sponsor
Not something we have researched to compare.
__________________
Scott Rudowitz
O: (1)250-485-5126
www.velocityap.com
Gazinsky
Dec 10, 2025 04:12 AM
Gasman2
Sep 7, 2023 10:50 AM
aimulaidni
Jul 8, 2021 02:21 PM
SinF
Sep 2, 2017 01:23 PM
jaggirl75
Nov 4, 2014 10:37 AM
