Lost Audio. Help!
Old Feb 14, 2019 | 08:27 AM
fujicoupe's Avatar
Banned
Default Lost Audio. Help!
Yesterday as I began a short trip my audio was missing--no radio, blue tooth, phone, parking sensor beeps, nothing. Three hours later when I started the car to return home everything was normal. The only audio function I didn't think to check was the GPS, but I assume that uses the same circuitry.
Anyone with any ideas as to what may have caused this malfunction? I shudder to think of the worst case because my Ghibli needed the TGW unit replaced twice when it kept losing audio for no apparent reason.
Old Feb 14, 2019 | 12:29 PM
FType17's Avatar
Same exact issue yesterday. Disconnected and reconnected battery, issue solved.
Old Feb 14, 2019 | 03:18 PM
eeeeek's Avatar
The same thing happened in my SO's Velar. I basically had to 'reboot' the system by shutting the vehicle off, waiting awhile and turning it back on. I'm starting to miss the ol' two dial radios.
Old Feb 14, 2019 | 03:36 PM
Unhingd's Avatar
Yeah...with vacuum tubes.
Old Feb 14, 2019 | 04:43 PM
scm's Avatar
scm
And a buzzing inverter ....
Old Feb 14, 2019 | 07:14 PM
DJS's Avatar
DJS
Had this happen once in my XE with ICTP. Hoping a software update will help - I’ll have that done at the first service this spring.
Old Feb 15, 2019 | 07:55 AM
fujicoupe's Avatar
Banned
That is exactly my plan since first service is due in April and it's a four hour round trip to the nearest dealer, but I was surprised at how much I had come to rely on the warning beeps.
Old Feb 15, 2019 | 12:40 PM
FType17's Avatar
Issue happened again. If you have a Bluetooth connected phone, try and turn off Bluetooth on the phone. Within 5 seconds my audio returned. Can anyone else attempt that when the issue repeats and see if this cures it? TY
Old Feb 15, 2019 | 02:35 PM
Unhingd's Avatar
+1. I have experienced the same issue depending on the sequence with which you connect the Bluetooth and hit the my music button.I just attributed it to user error.
klitfin
Jun 30, 2018 06:22 AM
redcamel
Jun 15, 2015 08:59 PM
daboss085
Jul 11, 2012 05:46 PM
papagreen53
Sep 14, 2011 09:10 PM
New2Jag
Sep 13, 2011 09:33 AM
