low battery and indie inspection
Old May 9, 2018 | 04:57 PM
jaguny's Avatar
Default low battery and indie inspection
Ever since the local shop plugged into the OBD port for the state inspection, I'm getting the low battery signal overnight. Could this short plug in have the car thinking it's still diagnosing and running down the battery?
Old May 9, 2018 | 05:14 PM
uncheel's Avatar
Doesn't seem likely, but try disconnecting the battery for a few minutes and reconnecting it to reset. Also, if you have a tender, give it a full run.
Old May 9, 2018 | 05:32 PM
Unhingd's Avatar
Plugging into the OBD port for any amount of time can confuse the battery management system. The battery disconnect does not need to be for more than about 15 seconds.
Old May 9, 2018 | 05:41 PM
sov211's Avatar
It is not only possible, it is what happened. If they did not shut down the program for the OBD II reader before unplugging, that is what happens. Disconnect your battery, wait for a minute, reconnect. Solved. There is a thread on exactly this issue.
Old May 9, 2018 | 06:07 PM
jaguny's Avatar
I told the indie this but was dismissed as not plausible. Thanks gents.
Old May 9, 2018 | 07:23 PM
jaguny's Avatar
Can you just pull one of two battery terminal cables or both? Do you lose any settings for the car.
Old May 9, 2018 | 09:08 PM
OzXFR's Avatar
Easiest way is to disconnect the earth lead from where it bolts to the floor of the trunk - a single 14 mm (maybe 13, maybe 15, I forget now!) nut.
You don't need to disconnect both positive and negative/earth, just the earth does the trick and it's much easier than the negative or positive battery terminal lead.
The only settings I have ever lost are the one touch window up/down, easy enough to reset (although for some weird reason in my case the car has to be moving!), and you will lose your Trip A and Trip B figures.
Old May 9, 2018 | 09:41 PM
jaguny's Avatar
Thanks Oz.
scarbro2011
Jul 24, 2016 05:28 PM
nasomi
Mar 10, 2016 08:38 AM
mr smith
Sep 29, 2009 11:15 AM
