Lower Steering Wheel Trim Part No?
Old Jul 22, 2020 | 02:11 PM
OnlySlightlyEvil's Avatar
Default Lower Steering Wheel Trim Part No?
See below image - I need this part. Mine looks like ****. Flat bottom wheel, black.
Old Jul 22, 2020 | 05:40 PM
Therock88's Avatar
Found this part number for 2014-2017 Flat Bottom, but it says "w/R". Do not see any without R? You can start here...
DC
Found this too. Check link....
https://parts.jaguarlandroverclassic.../brand/jaguar/
Old Jul 23, 2020 | 03:50 AM
Guardian's Avatar
On the back of non-R-badged I found only this number: 6254491
Old Aug 27, 2020 | 09:49 AM
SS4PK's Avatar
Here are some part numbers for future reference.T2R18060 upper $60.44 black
✔️Upper gun metal T2R19453 $110.95
Lower gun metal T2R24259 $150.
✔️Lower silver T2R24260
✔️upper silver T2R24258
(✔️confirmed)
Old Aug 27, 2020 | 09:55 AM
SS4PK's Avatar
Re
Here is a photo of the attachment location of the airbag as seen through the access hole on the back of the steering wheel via Bluetooth camera. In the picture The round wire, needs to be moved to the left past the tab. The wire is attached to the airbag, the tab is attached to the steering wheel. A small screwdriver is needed and the camera helps to see in real time.
Old Feb 8, 2021 | 10:41 AM
samit's Avatar
I just finished replacing the steering wheel trim and switches on my 2014 V8 S, which has a flat bottom heated wheel. Jaguar's part descriptions are rather vague and I had some trouble finding the correct parts, but I found the Jaguar Land Rover Classic Parts website to be by far the easiest for locating the latest part numbers.
Here are the parts I used, and can confirm fit and function perfectly:
  • Upper trim: T2R18060 (black, as mentioned above)
  • Lower trim: T2R18061 (black, without R)
  • Right switch panel: T2R16457 (heated wheel, cruise control)
  • Left switch panel: T2R19032
Also, like SS4PK said, if you are planning to do this, do yourself a favor and a buy a cheap Bluetooth borescope camera. I would probably still be trying to undo the airbag clips if I wasn't able to see what I'm doing.
Old Apr 8, 2021 | 11:05 AM
Armyair's Avatar
Does anyone have access to a part number for the lower flat bottomed steering wheel trim in black with SVR badge. Or able to point me in the direction.
frostysauce
Aug 11, 2021 10:41 PM
STMPY
Jul 9, 2021 09:21 AM
robbing
Jan 18, 2017 06:32 PM
bigmatt357
Feb 18, 2015 04:26 PM
mikesmith2
Nov 26, 2013 11:56 PM
