luggage compartment
Old Aug 14, 2021 | 11:28 AM
fssutton's Avatar
Default luggage compartment
Any ideas, coupe luggage compartment will not lock?
Old Aug 14, 2021 | 11:59 AM
scm's Avatar
scm
Do you have keyless entry? Try the trunk with the fobs a long way away ....
Old Aug 14, 2021 | 12:19 PM
CJSJAG's Avatar
Not sure whether the coupe is same as the vert in having an "emergency" interior trunk release.
Doe not make much sense in the vert as you can barely fit a hamster in there.
But if you have the interior trunk release you might check to ensure it is not somehow obstructed in the "open" position.
Old Aug 14, 2021 | 12:51 PM
scm's Avatar
scm
My coupe has the emergency release.
Old Aug 15, 2021 | 09:13 AM
Carbuff2's Avatar
The US government (and perhaps other jurisdictions) mandates the emergency release handle that glows in the dark.
We do everything we can to protect our hamsters!!!
More seriously
Does the luggage compartment not LOCK, or not LATCH?
[QUOTE][Do you have keyless entry? Try the trunk with the fobs a long way away ..../QUOTE]
^^^ This... get those fobs a LONG LONG way away. Or shield them by placing them them in your fridge.
Also, replace the batteries if its been a couple years.
If its a latching issue, a few drops of a light oil on the latch pawl might do the trick.
Old Aug 15, 2021 | 09:48 AM
fssutton's Avatar
thanks a lot. Tried all suggestions so far. It latches but will not lock. The coupe has the emergency release and it appears to be as it was delivered.The rear lid will also pop up about an inch when that graphic is depressed on the key fob.
Old Aug 15, 2021 | 10:05 AM
Carbuff2's Avatar
Hmmm...tried Double-Locking? Just a W.A.G.
See the owners manual.
Old Aug 15, 2021 | 11:01 AM
CJSJAG's Avatar
Is it only intended to lock when the car is locked?
If so, do you have windows up and rest of car locked?
Old Aug 15, 2021 | 11:16 AM
scm's Avatar
scm
How are you testing that it's not locked? Are you keeping the fobs a long way away? If you have a fob close by you will always be able to open the trunk with the under-trunklid button (assuming keyless entry). Or is the remote app reporting the trunk is not locked?
Old Aug 15, 2021 | 11:22 AM
fssutton's Avatar
Thanks, maybe this will "break the code" as I will try it. Yes I have been locking the car using the fob and then opening the trunk via the undertrunklid button with the fob in my pocket.
Old Aug 15, 2021 | 11:38 AM
Valerie Stabenow's Avatar
Can you press the "close lid" button on the upper right edge of the open hatch lid? It's a graphic with the car lid open. MY2017 here, not sure all have that feature.
Old Aug 15, 2021 | 11:41 AM
fssutton's Avatar
Ok thanks everybody issue solved. I tried double clicking and then put the fob about 30 feet away and magically it worked as advertised.
Old Aug 15, 2021 | 11:50 AM
lizzardo's Avatar
I don't understand what the issue is. That is, if it's latched, how is it not locked? I have the automatic lift, so mine unlatches and opens when I press the button on the fob, and also if I press the button on the underside of the back if I have the fob with me. If I don't, the button on the hatch does nothing.
EDIT: I should have refreshed the page before I replied. D'oh!
Old Aug 15, 2021 | 01:00 PM
scm's Avatar
scm
So you finally took the advice I offered in post #2!
Old Aug 15, 2021 | 01:01 PM
scm's Avatar
scm
Powered tailgate is an option - my MY18 doesn't have it. Just something else to go wrong ...
Old Aug 15, 2021 | 06:25 PM
lizzardo's Avatar
Powered tailgate was not an option for me when I ordered to my own specs; it was standard. I'd have preferred without (weight and complexity).
ashapir3
Dec 4, 2022 02:58 PM
Dogbreath!
Jun 28, 2017 09:47 AM
jagtoes
Jun 22, 2016 07:44 PM
Rey
Jun 21, 2014 06:17 PM
Rahtok
May 1, 2012 08:46 AM
