Manual Transmission Fluid
Old Dec 22, 2021 | 04:47 AM
takeapieandrun's Avatar
Default Manual Transmission Fluid
Did a search and could not find any information on the subject. Has anyone changed their 6MT transmission fluid? Is it even needed? I understand typically gear oil is used for many manual transmissions.
I have some time this holiday season and will be doing a few fluid changes, thus am curious.
Old Dec 22, 2021 | 06:47 AM
Rummy636's Avatar
Maintenance
DESCRIPTION INTERVALS Normal maintenance Filled for Life Severe duty maintenance Change the fluid at 150,000 miles, 10 year intervals.Capacities
LITERS Transmission Fluid 1.2Lubricants, Fluids, Sealers and Adhesives
CAUTION:Use only Pentosin FFL-3 Manual transmission oil. Use of any other fluid may result in a transmission malfunction or failure.
DESCRIPTION SPECIFICATION Manual Transmission fluid GX73-M1R564-AA
Input shaft Grease GX73-M1R561-AA
Metal surface cleaner WSW-M5B392-A
High temperature grease Molecote FB180
Old Dec 22, 2021 | 06:57 AM
Carbuff2's Avatar
I would change it...but I'm **** about maintenance.
Some manual transmissions do best with specific friction additives (looking at Honda, here). But on those, frequent fluid changes even with aftermarket brews keeps syncros shifting smoothly.
I found some references to using Ford full synthetic MTF, also Pentosin FFL-3.
I'm sure someone with better SEARCH skills will find more details...once you get the part number for Jaguar OEM fluid, you could search THAT.
EDIT: Like rummy636. HeeHee.
Old Dec 22, 2021 | 11:10 AM
lizzardo's Avatar
I got some oil at the same time I got some for my differential. The one listed by Red Line is their DCTF. I cross-referenced it at the time on their OEM Compatibility link with the specification from ZF's website for the transmission.
I have not yet changed it, although I did change the diff oil.
Old Dec 22, 2021 | 08:44 PM
Yes I'm definitely going to do the diff oil, seems easy enough. And wow, I am surprised by a 10 year/150k interval. I have never changed MT fluid before so I guess I am just more used to 30k miles roughly with a lot of ATs. I suppose it is better than saying it is lifetime fluid.
Old Dec 23, 2021 | 01:34 PM
lizzardo's Avatar
A change interval of 10 years/150k miles is too long for me with the engine running closer to the rated torque limit of the gearbox. I just didn't get it done before the weather turned, and with needing to work in the driveway it's going to wait for a bit. At only 45k miles I'm sure things are OK waiting for spring. I'm not driving nearly as much these days.
Old Dec 23, 2021 | 03:21 PM
Carbuff2's Avatar
LOL
Ours needed 3 days of soaking in PB Blaster (penetrant) before I could release the fill nut. (ALWAYS release the fill before draining!)
<SEEMS> is the key word...
Old Dec 23, 2021 | 07:11 PM
lizzardo's Avatar
Originally Posted by Carbuff2
LOL
I'm happy to live in a place free from salted roads. Mine was easy, except for working with the car on fairly low ramps.
Old Dec 23, 2021 | 10:25 PM
Therock88's Avatar
Here is likely all the info you will need on your Manual Transmission...Hope this helps.
I also have several DIY's on here for the Transfer Case, and Diffs.
Good luck...And Merry Christmas...
DC
Old Dec 26, 2021 | 11:10 PM
Much appreciated Rock. That's a very detailed PDF, I'll save it to read for later. Haven't actually gotten around to my oil change yet, so will be doing this a bit later since I am prioritizing that.
Old Jan 8, 2022 | 02:46 AM
So I went down the 'oil thread' rabbithole, mostly on various BMW forums. Seems like Pentosin FFL-3, which is also used by Porsche PDKs, is equivalent to BMW MTF LT-5 (also stated by ZF). There seem to be many OE replacements from various manufacturers (Amsoil DCT, Redline DCTF, etc) for these two, which are <$20. Although for a minor savings, might as well go with the ZF recommended Pentosin.
Old Jan 8, 2022 | 07:04 AM
Carbuff2's Avatar
That is my philosophy:
Since I'm doing the work myself, its STILL better to spend a couple bux extra on factory parts.
Especially with fluids of unknown friction characteristics...I am skeptical of "Jack-Of-All-Trades fluids.
Old Jan 8, 2022 | 10:37 AM
lizzardo's Avatar
If I had an automatic I'd be more inclined to use only the specific, manufacturer's recommended fluid, but a manual transmission is a more straightforward mechanism. I'm confident the Red Line equivalent will do the job, and still have some residual loyalty to Red Line from my racing days.
Old Jan 16, 2022 | 11:03 AM
rbsj's Avatar
Default 2016 black base 6-speed manual F type w/ low miles
In the Chicago area if anyone is interested:
https://www.cargurus.com/Cars/invent...ting=321353799
juuan26
Jul 27, 2018 12:59 PM
Lubino Do Rego
Jan 30, 2016 03:04 AM
SoCal Babe
Apr 12, 2014 03:30 PM
Jaguila
Feb 10, 2014 04:57 PM
iownme
Jul 12, 2011 07:53 AM
